Cam & lifter change with afm delete?
Old Dec 11, 2012 | 06:12 PM
Bowtie972's Avatar
Default Cam & lifter change with afm delete?
With the afm delete kits is a cam & lifter changer required? or can i use the new lifter valley cover parts and leave oem cam & lifters with out any problems? This is a 2008 5.3 from a silverado
Old Dec 11, 2012 | 06:16 PM
Tainted's Avatar
All of it goes. The dod/afm cam and lifters as well as valley cover are all different and MUST be changed
Old Dec 11, 2012 | 06:37 PM
Bowtie972's Avatar
Ok, Thank you. Any suggestions on a particular kit? What cam choices would be compatible to keep the efi? Im not looking for crazy HP, i wasnt even goin to do a cam swap right now, but if its required i will. This is basically gonna be a street cruiser and occasional long run, in a 70 Nova,
I guess i should ask this, after the afm delete is this 5.3 as good as any other 5.3? As in older versions?
Old Dec 11, 2012 | 06:50 PM
Tainted's Avatar
Youre fine either way. Livernois sells a kit and so does TSP, howecer with tsp keep in mind ypu will still need a cam.
Old Dec 11, 2012 | 06:51 PM
Bowtie972's Avatar
Thanks for the help
Old Dec 11, 2012 | 08:39 PM
litle88's Avatar
You can gather a few used parts around here as well in the classifieds like the valley cover and front timing cover. You'll need an Ls2/3 valley cover, lifters, lifter trays, springs, a 3 bolt cam, 3 bolt timing set, Ls2/3 front timing cover. All which aren't expensive but I pieced one together cheaper than a kit for my brothers L99. I went with vendors that offer free shipping on orders over 100 and I googled the part numbers. It shouldn't be much for what your wanting outta the 5.3 IMHO.
Old Dec 11, 2012 | 08:42 PM
Tainted's Avatar
If youre wanting a cam you may look into the 224R for a smaller cam, or even a gm hot cam
Old Dec 11, 2012 | 08:45 PM
Bowtie972's Avatar
All good info, i appreciate it.
Old Dec 11, 2012 | 08:47 PM
Tainted's Avatar
Just keep in mind with a cam youre gonna want to change springs and pushrods also. Cam kits are generally $750. All in all, exect about 1300 for a total dod/afm delete and cam swap
