823 heads on gto
Heres the thing with ls3 heads on small bores.
Your intake valve is shrouded by the cylinder wall, thats going to hurt your flow.
next is your limited ptv clearance. Unless you want to flycut this will limit how much you can mill and how large of a cam you can fit.
The cathedrals you can have a larger choice in cams, mill for max compression, and with good port work they will perform just as good and through smaller runners at that.
If you're wanting to get jiggy with a big *** cam or high compression it's going to be tough to achieve such things with the limitations of the LS3 head on a 4.000 bore.
