pricing help in ls3 418 or 427
Looking to get either of the motors. About qhat coat will it take for a good stout motor. Randing feom5tp-600 rwhp. Best bang for the buck and. What will cost to build
Do the 416/418. There aren't any MAJOR reasons not to do the 429, but... I can think of at least 10 minor ones. Only difference between them is going to be 10-12 ft/lbs of torque anyway. If you want it to last a long time, smaller stroke is better
With stock sleeves, longer than 4" stroke is less than desireable for longevity (pulls the piston skirt out of the bottom of the bore and ring pack moved up decreasing piston crown strength). I would recommend a 416 (4.07" bore and 4.00" stroke).
