Link Bar Lifters: Comp vs Morel / Lunati
Old 05-05-2013, 10:19 PM
LPE 403's Avatar
Default Link Bar Lifters: Comp vs Morel / Lunati
Had a set of the Lunati 72437 fail on me - many of them stayed pump up, one simply was pumping up at all. Dyno time only, zero miles. Not sure the root cause yet, but will soon.
Haven't heard enough data on the new short travel lifters (Comp 15956) to definitively say it's a better plan, but have a set coming anyway.
I struggle in believing i could get another bad set of the Lunati / Morel lifter, but the thought of tearing my intake off again to even fix one...doesnt sit too well with me.
Thoughts, experience, etc appreciated...
Old 05-05-2013, 10:30 PM
lil john's Avatar
That's a good 1. I'm looking over lifter's now.Would like to see how it works out for you.
Old 05-06-2013, 07:57 AM
lil john's Avatar
Just called Vengeance racing for my lifters because cam lift is over .680 lift. I'll probably be getting Morel 5206's lifters and PAC1207X springs because I bought TFS ls3 heads bare.
Old 05-06-2013, 08:56 AM
Havoc40's Avatar
A properly set-up short travel system is usually worth another 500-1000 more RPM before valve float, in a given application. Throttle response almost always increased in the engines I've been involved with, after switching to short travels. They work well because of the amount of time needed to replenish the high pressure chamber (area below the plunger) inside the lifter with oil. The key is to get the proper preload on every lifter. This will require measuring all 16 and ordering a few different length pushrods. I don't agree with Comp's .002"-.004" preload recommendation. I'd set them in the .030" area to account for expansion and quiet them down.
Old 05-06-2013, 11:07 AM
chrs1313's Avatar
What preload was used on the lunati lifters that failed?
Old 05-06-2013, 11:18 AM
LPE 403's Avatar
.050 according to the builder.
Old 05-06-2013, 12:39 PM
Havoc40's Avatar
There's only a few ways this can happen if the piston is still freely moving, and just not pumping up. The I.D. of the lifter body or O.D. of the piston could be slightly O.O.R., and once it ran for a few the leakdown went out the window. Low leakdown to begin with. Or the check ball in the piston isn't sealing, caused from various issues but most commonly debris. A couple microns is all it takes in some cases.
Old 05-06-2013, 12:53 PM
LPE 403's Avatar
Thanks....that seems to be the concencus and hope to find out for sure this afternoon. This has apparently happened on a number of other occasions, which has me concerned in pursuing the Morel / Lunati again.
I do like the idea of additional valve train stability and throttle response (though isnt going to be a problem - ITB), but I'm concerned about your thoughts on pre-load. Isnt the full travel of these lifters about half that?
Old 05-06-2013, 01:07 PM
Stage7's Avatar
Morel (and the Morels badged as Lunatis) are pretty much the creme de la creme of hydraulic lifters.
No personal experience with the Comps, but I'd have a hard time believing the Comps are a step up.
Old 05-06-2013, 01:12 PM
Sommer86's Avatar
I went with Johnson short travel linkbar lifters.
Old 05-06-2013, 01:22 PM
Havoc40's Avatar
Comp's have .050" travel. Once everything expands, you'll be running ~.020" preload setting them at .030" cold. I'm not a fan of running hydraulics with lash, which is what happens with the recommended preload. Ask Rickenbackerman about Mamo's recommended preload on the Comp's, IIRC it was also around .030". Between mine and my customers projects, I've seen short travel engines spinning 8500+ with no issues. This is with .060" travel lifters set to .030-.040" preload. Of course, it takes a certain attention to detail to achieve those numbers (not that your work of art is short of that).
Old 05-06-2013, 01:30 PM
babbage1109's Avatar
Where do you order those Johnson lifters?
Old 05-06-2013, 04:13 PM
Gray86hatch's Avatar
Debris is what most of the time causes lifters to not pump up.
Morel stuff has proven it self time and time again.
Tim
Old 05-06-2013, 05:42 PM
litle88's Avatar
morels here and no issues preload set at .050
Old 05-06-2013, 05:53 PM
Sommer86's Avatar
I got them through Tony Mamo.
Old 05-06-2013, 06:22 PM
chrs1313's Avatar
Was it a fresh motor?
Old 05-07-2013, 08:41 AM
Ron@Vengeance's Avatar
Thanx for calling. If we can help you out feel free to contact us.
Old 05-07-2013, 03:08 PM
rocket69GTP's Avatar
Do you have any pics of said lifter? I just had a set of the Lunati's (same exact part number) fail me two weeks ago and lost the cam in the process.
Old 05-07-2013, 05:29 PM
WKMCD's Avatar
I have about 7 or 8k miles on the Lunati/Morel in my build with no problems.
Old 05-08-2013, 07:11 PM
LPE 403's Avatar
I do not....wish I did. Sent to the builder, never to return.....
New lifters on the way...non-sponsor. For details, feel free to PM me.
Comps are for sale
Quick Reply: Link Bar Lifters: Comp vs Morel / Lunati
