LY6 Inconel exhaust valves
Im assembling a bare set of LSA heads for my 370 FI build. I have a set of LS3 hollow stem intakes and for the exhaust I have a set of valves I pulled from a 08' LY6 6.0 engine that was in a boat. I have heard over and over again that the LY6 exhaust exhaust valves were made of inconel but I see surface rust on the lower part and I was under the impression that inconel was rust resistant. As a matter a fact I put them side by side to the LS3 exhaust valves and they are identical in every way, both are non magnet with a welded tip, both weigh approx 90 grams, and both will rust.
So this said my question is how am I supposed to tell for sure if these are inconel or just a regular old valve? There is at least a part number on the intake valves but no such thing on the exhausts. Any help is appreciated, Thanks
Inconel = $$$. I retired from the oil industry a few years ago. When specc'ed, a 2" Inconel globe valve was over $10k vs around $500 for a carbon steel valve. I would assume this cost ratio could be directly applied to an automotive valve. In other words, I do not believe GM would intentionally spend unnecessary money on valve material...
ive been getting my setup from brian tooley, since im going to be getting a custom cam from him, he suggested i run ls3 intake & the stock ly6 exhaust in my sprayed 6.0 and im gonna take his word for it
