TrickFlow GENX 255cc LS3 Heads
"Im really pleased how these turned out....I got back home at 2:45 AM after flowing your heads and putting custom valve jobs in a few other pairs of heads I'm working on as well....it was a long night but flowing your heads was the highlight. You need to keep in mind that we milled a fair bit off them which always reduces flow numbers a little bit....sometimes more than a little bit and i also flowed them on a real world 4.060 bore to better simulate your actual bore size (the numbers would have looked better if i used a 4.125 or 4.155 bore).
Anyway....here is where we ended up
Lift.......Int.....Exh
.200....151....122
.300....232....176
.400....298....220
.500....345....240
.550....362....247
.600....387....253
.650....393....257
.700....394....260
Exhaust numbers are tested with a 1.875 flow tube thats shaped just like a conventional header.....same tube I use on ALL my SBC testing.
.200....151....122
.300....232....176
.400....298....220
.500....345....240
.550....362....247
.600....387....253
.650....393....257
.700....394....260
ETP C5R 240cc test bore 4.125 2.180/1.625 valves
.500 325/232
.600 363/240
.700 388/242 $3199.oo
ETP C5R High Port 255cc 4.155 test bore 2.200/1.600 val. 44.5cc's
.500 334/236
.600 358/252
.700 382/262
.800 393/265
No price and no longer made MAST C5R HEADS are 290 cc
These were the cream of the crop not to long ago Im just waiting 4
SOME 1 TO MAKE A
GOOD bare CANTED HEAD FOR
LESS THAN 2500 Cnc ed for the pair
Now looking to do Cuda Shaker hood scoop on a 80's Malibu.
