Aluminum 454 Build
Is that a wet sump?
Looks like a mechanical water pump - how are you planning on driving that? I ask because your damper and it look like they are way offset from one another.
Do you have a number in mind you're wanting to see?
I am pulling for you big numbers man! Best of luck! Sorry for the 100 questions...
Yes it is wet sump...the pan only holds 5.5qts, but I plan on running a remote filter that holds a quart, and an oil cooler, all with -12an lines so it should hold around 7qts all together.
I have a pulley that bolts to the dampener, but for the dyno they will just use their electric pump and run the water through my pump...not actually spin my pump, but just use it to hook up to their pump.
As far as numbers...my dream number is 875hp at the crank, but I will be ecstatic with anything over 800hp
I look forward to seeing the individual filters - that will look so badass under the hood. Just saying "454 Chevelle" puts a smile on my face.
875HP HOLY PETER CHRISTMAS
800HP is still absolutely nuts N/A. I used to dream about twin turbo V8s making that kind of power BHP.
Looking forward to Tuesday. Let's go 800BHP+
