Aluminum 454 Build
Katech struggling to make 700 hp with a 454 using the same ITB setup was enough to scare me off...
If I had more time I would be more willing to spend hours on PipeMax figuring it out, but I barely have enough time to take a poop...
Pressing out the stock nonsense...
The devil bearings themselves.....
Pressing in bearing number 1
Put in the trunnion and pressing in the second bearing...
Then I had a set of trunnion upgraded rockers that I had to put snap rings on....and then wait until I have a set of heads to install them in...
And lil...I looked at that before...I just can't run a hydroboost setup due to using the billet specialties tru track PS pump
I would run ductile iron seats and have the titanium valves coated. There's a reason GM did this with their heads...
On a side note I will be ordering a timing set soon.... Is this a good choice? Also it says that chain is available separately...is this just meaning that incase it needs to be replaced it is available, or does it mean that I would have to buy the chain separately?
http://www.briantooleyracing.com/com...et-3172kt.html
