Aluminum 454 Build
It very well may which would allow you to run a larger cam.
Fat and nasty is my middle name....
The test has been done and the results have spoke.
This is why I'm a firm believer in talking to the people who have actually done ****. Because everything work out this way or that way on paper. But in the real world it could very well be different.
Halltech had a 427 and wcch ls7 heads
If those ITB intakes were as badass as everyone says they are you would be making closer to 700rwhp in my opinion.
Sheet metal intake with a big cam and wcch ls7 heads have done 660rwhp at 427inches
I would be looking at one of those if I felt the fast wasn't enough for me.
But if you have the room a mast or other carb style is probably going to be the best for all out power.
I think that one Monte Carlo is doing close to 700 at the tire stock ls7 castings and stock shortblock
670ish rwhp stock heads plastic intake
You are the only one assuming things.
You have dyno numbers for your car, but you assume there is alot left.
He'll I've thrown together ls7 crap that made 560rwhp without any dyno tuning 18 degrees and through drivetrains that rob more than yours.
Hell with ported heads and a not stock tb I'd probably make close to what yours did. And it was only a 429 with a powerband like a truck.
If you want to see something that makes a proven mid 600rwhp there are a handful of ls7 cars I can think of on the corvette forum.
If you want hear about speculative mid 600rwhp set ups keep talking to these guys.
But none of them look as badass as the kinsler so good choice..
Sounds like you're well on the way to making 600rwhp or more
Sorry OP, moving on....
