402 LS2 Built motor Price? 502 RWHP / 486 RWTQ
I'm wanting to go with a 5.3 motor with 67mm turbo for my car now instead of my 406. I'm putting down 502 rwhp / 486 rwtq currently. Not sure on what the price would be if I sold complete other than oil pan. The details as followed.
LS2 Gto Block. 402 ci
Callies Crank and Callies Rods
Malhe -10cc Piston
Fast 102 Intake
46 lbs Fast Injectors
239/247 113+1 cam
Dual springs / Titanium retainers, 7.45 harden push rods
Port oil Pump
Ported TB
LS6 Stage 2.5 Heads TSP with more hand porting after
Complete Arp Bolts
25% UDP
Motor has maybe 500 miles on it.
What is a good price to sell? Thanks for the help.
Malhe -10cc Piston
Fast 102 Intake
239/247 113+1 cam
Port oil Pump
Ported TB
Complete Arp Bolts
25% UDP
Malhe -10cc Piston
Fast 102 Intake
239/247 113+1 cam
Port oil Pump
Ported TB
Complete Arp Bolts
25% UDP
Malhe -10cc Piston
Fast 102 Intake
239/247 113+1 cam
Port oil Pump
Ported TB
Complete Arp Bolts
25% UDP
Ok you twisted my arm ill give you $1000 if you deliver it to England for me
On a serious note it looks like you've got all the right bits there its hard to say
The motor block work was done by Wall to Wall in Livingston,LA.
All the parts came from Texas Speed & Performance and I put the motor together. Tuned by myself.
Putting a turbo setup in this weekend I should start. Was thinking of 5.3 built or stay with the 402 and a S475 T6.
