6.0 build suggestions..
Nope...If you did anything get the heads ported....and a cam........ stay at 6.0
Just do this go look up: Hot Rod LS Cathedral Port comparison all heads are Cathedral
style except 1 head Mast Medium bore heads and at that particular lift and horsepower requirement .........................The rest will speak for itself also look at the difference in the stock ported heads.
TEA LS6
Retail price: $1,320 (porting on customer-supplied head castings
ProComp Motorsport LS1****** Also made the most power and it's a Knock off head********
Retail price: $1,875
A 4.0 bore shouds the valve too much with an LS3 head and kinda limits the power to be had. If you go 6.2 it helps to unshroud the valve and make more power.
No matter what head you go with make sure you cam them accordingly. LS3 heads don't need big donkey dick cams to make power. Most stock cubic inch LS3's use 22x/23x cams and make damn near 500 rwhp.
This build will be over the winter so im in no rush.. I want to make AS MUCH power as I can Naturally aspirated. Thats why Im thinking about boring it. And using LS3 internals.
If you decide to try and bore it to 4.065, make sure you have the bores sonic tested to ensure the bores can safely handle that large of a overbore. 4.065 seems to be the magic minimum bore required to make the LS3 heads come alive.
Martin Smallwood (sure there is a joke in there somewhere, but Martin seems like a cool dude and knows his **** ) of www.Tickperformance.com spec you a cam reguardless what heads you run.
do i need a special ecu to retain these functions/ the motor is a 2010 ly6 block.
58x tooth reluctor
