PRC 225 "as cast heads" Feedback?
How much rwhp do you think they would make?with this set up:
2005 Gto m6
Stock ls2 short block
233/239 cam on a 111 lsa
225 heads
Fast 102
1-3/4 arh
UDP
Ported 90 tb
Hendrix power chamber
46lb inj
The obvious advantage of getting the as-cast heads is the room for growth they offer if you ever choose to send them back to be CNC'd.
Flow Data:
4.00" Flow Plate - No Exhaust Pipe
LIFT INTAKE FLOW EXHAUST FLOW
.100" 68 CFM 56 CFM
.200" 145 CFM 113 CFM
.300" 210 CFM 164 CFM
.400" 257 CFM 200 CFM
.500" 300 CFM 214 CFM
.600" 318 CFM 229 CFM
.650" 321 CFM 230 CFM
How does "no pipe" vs a pipe or other setup affect the flow numbers ?
Does one tend to "inflate" the numbers ?
Either way, it's really hard to compare flow numbers across vendors. The fixture, flow machine, and how the test is conducted can all change the characteristics of the flow pretty significantly and make comparing heads by CFM pretty worthless.
