LSX454 camshaft, will you consider it as a mild cam?
I'm looking for an engine that would give me 500-550 RWHP and yet be used as a daily driver with good idle characteristics and would pass our local emissions test (for classic cars it should be less than 4.5% CO and 1200 PPM HC), this is the cam specs as per GM site :
Maximum lift is 0.600/0.600" with 1.7-ratio rockers and 0.635/0.635" with 1.8-ratio rockers. Duration is 236 degrees on the intake side and 246 degrees on the exhaust side, with a 110-degree separation angle
what I'm concerned about is the tight LSA of 110*, yet a few guys consider it as a "mild" cam!
For the people who used or have an in-sight idea about the GM LSX-454 crate engine, do you recommend it as per my criteria?
While there's a lot of valuable information on this site, your best bet would be to get with a custom cam designer and go over your build in detail with them. Be honest with yourself, and the designer about your goals. I've heard customs spec'd on a 114 that sound rowdy as hell.
It's all about manipulating valve events and cylinder pressures when it comes to cams.
I'd strongly recommend Brian Tooley or Pat G.
Talk to a cam expert for a custom grind to suit your goals. I would say the cam you have suggested is about 10 degrees to big. Something like a 22x/23x 115 would be in the ballpark IMHO.
I strongly agree with talking to Brian Tooley.
I run an ERL 447 with BTR TFS 245's and his spec'd cam and I love it.
my specs are 251/262 .623/.596 114+4 has a lumpy idle, but drives great.
I spoke with Allen from BT Racing regarding a custom grind for a LSX454 and they came up with 234/246 .648/.630 115+3, what I need from this engine is a smooth idle at around 700-800 rpm with A/C on, and yet can generate 500-550 RWHP. What do you guys think about it?
