5.3 vs 6.0 iron block to get 9s 1/4
Hey guys I am slowly planning my build for a 9 second car. I will be running in a 1974 260z. Car weight should be in the neighborhood of 2500lbs when I am done. I can't decide if I should go with the lq4 or the 5.3. The plan is to get an engine either out of an auction vehicle or the junk yard and start my build from their. Estimating about 15k for the build. Need some help with what direction I should go and if I should stay NA or go FI. plan is to run a built T56 and not 100% on the rear end. I am estimating I will need about 500 whp to get the job done but I want to make sure the car is extremely reliable as well. I wouldn't mind being able to turn up the boost and make 600+ whp when I go to the track so turbos are on the table but that will be an extra $4k or so so just not sure need some input. It seems the best way to go NA would be to get the 6.0 and do a 408 stroker kit. Well any advice is appreciated!
I did look into the aluminum block put the price difference is a 408 stroker with forged rods and piston. plus the platform is so light as it is I don't feel the need to cut the extra 100lbs. Plus since some day I may get bored with 500hp. and the iron block is just so much more capable of boost so while I am not against an aluminum block, to me, iron just makes a lot more sense.
MASS seller approved
Iron 5.3 or 6.0 boosted will get you 9s. 5.3s more plentiful and cheaper. If doubts about 5.3 boosted...google Gunsmoke Tellez Motorsports. Gunsmoke is a heavy full size gm truck with a boosted 5.3 running 9.9s so imagine what your lightweight car could run...hmmm....
Thanks for the replies guys. I wont be using nitrous it has never really interested me. It seems most people suggest going boosted. I will do a bit more research but I have pretty much decided to go with a 6.0 and thinking of just getting some turbos off of a turbo diesel and going from there. Should be getting the engine in the next few weeks and will start a build thread.
A LQ9, ported heads and cam swap along with a small (150) shot of N2O will be a tough combination to beat for the price - especially in a 2500 lb car. If this is a drag car, you will go faster with a stalled auto and break a lot less parts in the process.
