Aluminum 441 build on corn
Old Jul 9, 2017 | 02:25 PM
  #101
BennyB's Avatar
Originally Posted by Pantera EFI
Hi Benny, yes a know value if I new your MAX RPM ? (8000 ?)
My PMG Alternator should be finished (proto) in thirty days, with "beta" units is sixty days.
That is a 12K Max RPM Armature with embedded magnets. (N-52)
The CAD will be done by Casey Wegner, a team member.
Lance
I'll be running the fast 102 at first so I'm going to say 6800-7200
Old Jul 9, 2017 | 04:21 PM
  #102
pantera_efi's Avatar
Default Alt rpm
Hi Benny, I would "spec" a 3.75" Alt Pulley.
GM OEM or MY BAS.
Lance
Old Sep 24, 2017 | 08:41 PM
  #103
BennyB's Avatar
Well the engine/trans are finally in. Having a slight issue with the TSP 2" headers. The passenger side is resting against the frame so going to try and pry it out some. I was also having a bad time trying to get the steering shaft lined up and back on. I'm going to start on it again and see how things go tomorrow. Anyway, here are some pics
Old Sep 24, 2017 | 09:14 PM
  #104
tug686spd's Avatar
On the passanger side header mine contacted the frame also. If its the same spot as mine and your seeing it from the top it actually just a tab extending down from the frame. I just bent the tab over on a 45 and all was good. Glad to see your still working on her.
Old Sep 25, 2017 | 07:38 PM
  #105
BennyB's Avatar
Yeah I bent that tab over, but the header is still resting on the frame right above it. It's not bad so I should be able to pry it away a little to get the clearance I need.
Old Sep 25, 2017 | 07:40 PM
  #106
BennyB's Avatar
Old Oct 1, 2017 | 07:48 PM
  #107
BennyB's Avatar
Figured out most of my issues with the header and tailshaft alignment. Loosened all motor mount hardware and ratchet strapped the tailshaft over to get everything aligned where I needed it and re-torqued all hardware. Everything is lined up pretty good now.
Old Oct 8, 2017 | 04:44 PM
  #108
BennyB's Avatar
Old Oct 21, 2017 | 09:38 PM
  #109
BennyB's Avatar
Old Oct 23, 2017 | 09:04 PM
  #110
tug686spd's Avatar
She's got to be close to firing up.
Old Oct 25, 2017 | 07:18 PM
  #111
BennyB's Avatar
Man it’s really close, just waiting on the rest of my AN fittings and hose to show up. I need to see about getting a “first startup tune” as well.
Old Oct 25, 2017 | 09:27 PM
  #112
tug686spd's Avatar
Sucks waiting for the little stuff. You know you have to wait on the big still like motor, tranny and rear but waiting for a couple days on that one fitting you didn't order is the worst. I'm sure I'm not the only one waiting to see this thing completed.
Old Oct 26, 2017 | 01:49 PM
  #113
BennyB's Avatar
Exactly! I guess that’s just how it goes though
Old Oct 26, 2017 | 10:02 PM
  #114
BennyB's Avatar
Old Oct 27, 2017 | 07:24 AM
  #115
Double06's Avatar
Default Valley Cover Button Head Bolts
If you put manifold on already then it can wait buy these and put in tool box when manifold is off next time. I find that the stainless steel button heads the alan key part can strip when tq is applied. I went to hardware store or Fastenal and got the grade 10.9 or 8.8 button heads they don't strip as easy.
Old Oct 27, 2017 | 09:18 AM
  #116
BennyB's Avatar
Thanks for the insight, I will definitely keep that in mind
Old Dec 11, 2017 | 09:50 PM
  #117
BennyB's Avatar
Finishing up the small stuff. Fuel system coming together now
Old Dec 15, 2017 | 06:06 AM
  #118
BennyB's Avatar
Old Dec 15, 2017 | 11:07 AM
  #119
tug686spd's Avatar
Little by little it's getting closer. Keep chipping away at it.
Old Dec 15, 2017 | 06:27 PM
  #120
BennyB's Avatar
Thanks man and yeah little by little lol
