Aluminum 441 build on corn
Old Dec 15, 2017 | 10:02 PM
  #121
blk00ss's Avatar
What fuel rails are you going to use?
Old Dec 17, 2017 | 10:22 PM
  #122
BennyB's Avatar
I am running the fast fuel rails
Old Jan 12, 2018 | 03:48 PM
  #123
BennyB's Avatar
For those that mount the fpr and fp gauge directly off the fuel rails, did you have any fitment issues? Looking at hood clearance, seems like it will be close.
Old Jan 14, 2018 | 06:29 PM
  #124
MrblackZ's Avatar
Very nice build! How much more do you have left?
Old Jan 14, 2018 | 08:40 PM
  #125
BennyB's Avatar
Down to the nitty gritty now. Got some wiring to do yet for trans brake, line lock, trans temp gauge, etc. I am sending the ecu off for a start up tune. Then it will be time for some dyno tuning.
Old Jan 14, 2018 | 08:53 PM
  #126
01CamaroSSTx's Avatar
Words cant describe the moments leading up to that initial startup!
Old Jan 14, 2018 | 10:05 PM
  #127
Originally Posted by 01camarosstx
words cant describe the moments leading up to that initial startup!
word....
Old Jan 22, 2018 | 02:02 PM
  #128
Mavn's Avatar
"I MAID THEESE"
NEED STARTUP and NUMBERS
Old Feb 3, 2018 | 07:21 AM
  #129
BennyB's Avatar
Old Feb 3, 2018 | 07:24 AM
  #130
BennyB's Avatar
It’s getting there. Fuel system is complete minus new fuel pump, so I need to drop tank and do that. I need to send the ecu to Justune to get a start up tune and radiator/ trans cooler need put in. Then it will be ready for first start. Still have some odds and ends like trans temp and shift light wiring, but we are getting closer!
Old Feb 7, 2018 | 04:35 PM
  #131
Mavn's Avatar
"I MAID THEESE"
FACKKKk
Old Feb 18, 2018 | 09:47 AM
  #132
SICK WS 6's Avatar
Awesome work man! Can't wait to see how it turns out.
Old Feb 18, 2018 | 10:27 AM
  #133
Fivethree twinturbo's Avatar
Interested to see how it runs!
Old Mar 10, 2018 | 09:41 PM
  #134
BennyB's Avatar
Old Mar 10, 2018 | 09:51 PM
  #135
BennyB's Avatar
Just a few updates
Old Mar 23, 2018 | 11:13 PM
  #136
BennyB's Avatar
Old Mar 23, 2018 | 11:14 PM
  #137
BennyB's Avatar
The car is back on the ground... for now. I need to get the rear end up on jack stands and drop the fuel tank to remove any old fuel and to install the walbro 450. The front end definitely needs to be aligned and I’m going to have to mess with the ride height bc right now it’s sitting too low for comfort
Old Mar 23, 2018 | 11:50 PM
  #138
Nice work there, maybe one day my engine will reap the benefits of corn. Oh and for all the pcv "POLLUTION CONTROLLED VEHICLES" running out there. Here's another example of a person who doesn't want blow by gases disrupting his air/fuel mixture!
Old Mar 24, 2018 | 11:01 AM
  #139
Benny, what fuel pressure regulator you gonna run with the 450 pump?
Old Mar 24, 2018 | 05:56 PM
  #140
BennyB's Avatar
Yep, no thanks! I’ve ran many different catch cans with no luck, wasn’t going that route with the new setup.
