4" Stroke Windage tray?
Old Oct 3, 2014 | 06:41 PM
6togo's Avatar
Default 4" Stroke Windage tray?
Anyone running a 4" stroke GM perf. windage tray i need one for the LSX build and i know the stock trays can be spaced but i dont have one at all so i figured get one that requires no work to fit right!
Gm also has 4.125 and 4.200 trays just dont think i need more than the
4" one being thats what i'm at but i like to know if the 4" tray has ample clearance.
Old Oct 3, 2014 | 09:17 PM
gnx7's Avatar
I believe improved racing makes them also....
Old Oct 3, 2014 | 10:24 PM
6togo's Avatar
Thanks I will check them out!
Old Oct 4, 2014 | 12:57 AM
trevmust's Avatar
i'd just go with mast and a mast pan.
Old Oct 4, 2014 | 08:19 AM
6togo's Avatar
I have a custom sheet metal pan and the Mast tray costs $30 more.
Old Oct 4, 2014 | 03:25 PM
trevmust's Avatar
to each his own.
Old Oct 4, 2014 | 05:48 PM
Briou's Avatar
I am running the Holley retrofit muscle car pan with a 4.185" stroke, and all I had to do was space the L92 windage tray down with two washers on each stud...worked perfectly...So if you can find a stock one for cheap you can just space it down....not an aftermarket tray but just a thought....
Old Oct 5, 2014 | 01:16 PM
DietCoke's Avatar
mast tray.
Old Oct 5, 2014 | 04:07 PM
1989GTA's Avatar
If you buy the GM Performance part windage tray do you still have to modify the oil pan pickup tube to maintain the proper clearance?
Old Oct 5, 2014 | 06:51 PM
6togo's Avatar
I would not think so as the tray is probably lower in the center but still looking for anyone that has used them to confirm!
Old Oct 6, 2014 | 09:38 AM
ImprovedRacing's Avatar
LS1Tech Sponsor
Lowering the windage tray will lower your pickup tube as well. Bend the tube bracket to account for this and then measure the distance between the bottom of the pickup tube and the oil pan with molding clay/putty. You want this gap to be between 1/4" and 3/8".
__________________
Call Us: 407-705-3054 MON-FRI 10am-6pm EST
Like Us: Facebook - Twitter - Youtube
Old Oct 6, 2014 | 04:13 PM
6togo's Avatar
Yes that is with a stock tray any input on aftermarkets?
