angle milled ls3 head to 12degs
So anyone angle milled/decked an ls3 or other ls heads from 15deg to something like 12deg on ls7 heads?
There are benefits to angle milling but they come at a cost especially on street engine. When you angle mill heads you are also changing the angle of everything associated to them so for every degree you tilt the head you are causing alignment issues with the intake mating surface and intake bolts, The head bolts/studs now out of alignment and your headers may have clearance issues. There are many articles on the benefits but I think you'll find that they aren't that great unless you're trying to get every last HP out of a combination. Angle milling may gain 20-30 hp and that would be a worthwhile advantage on a 700hp circle track motor but probably not worth it on a daily driver.
Race only engine pushing 615+hp, running vac pump and yes definately trying to chase every hp
I have ran angle milled heads on vettes and camaros with no issues with stock or fast intake manifolds.
my machine shop matches up all the faces to the same angle as they do the heads.
about experimenting and trying weird stuff. not just calling up TSP or whoever and ordering a 400+ cuber with all the goodies.
If say to for it and post some pics/results.
Your idea isn't practical for lots of reasons....the largest one being you would mill into the water jacket on the plug side of the chamber. Just a 1 degree rollover is close to a .150 angle mill.....a 3' move (15' to 12') would literally wipe the deck out which your lucky if its .400.
Nothing would fit intake manifold related....you would push the engine off the side of a cliff before it was all said and done.
Take the plunge on some LS7 heads.....I have a set I have been porting for stock right now. 407 CFM and 270 exhaust.....good luck getting within 30 of that on an LS3 casting.....not going to happen.
Don't waste your time thinking of pursuing this any further....its just not going to happen
Hope you don't mind me sobering you up!
-Tony
i'm not going to a ls7 head and to some extent i don't care about big cfm ratings. this combo will be about cleaning up the flow thru the big ports, careful matching of everything to get a good ve.
i'd agree on the deck thickness at 400thou, if its not practical to go to 12 deg's, i'd be happy to try a degree or so.
manifold lining up is interesting, i've had both a plastic manifold and vic jnr line up fine on a current set of heads decked 100thou (when people swear it won't line up). i'm under no illusion angle milling will change things.
thanks kcs, will keep updated on how we go
Angle milling cost me 200 bucks.
Compared to 80 for flat milling at the same shop.
What would you spend 120 on to beggee improve performance??
3Pedals
StunningMan
IllusionalTA
IheartLS1
ThirdGenBum 2
DmMizell
06X6spdGTO
Each one of them has a single plane combo that is making about 65-85 more horsepower out of a 6 liter. I don't think any of them are doing anything unusual to do it. They are just doing the usual really well.
