cam install question
Old Mar 15, 2015 | 09:31 PM
edge04's Avatar
Default cam install question
installing a new cam. currently have heads off with long block in the car. stock crank, cam and crank sprockets and katech timing chain.
aside from verifying the cam specs, should I bother degreeing it? I bought the cam new from a very reputable cam builder. realize you can do other things but I don't own a degree wheel and would have to buy one. thanks
Old Mar 15, 2015 | 10:33 PM
CAMSTER's Avatar
If you have the OE crank and cam sprockets you can just install cam bottom up and go but if you have a multi choice cam sprocket you should degree the cam.
Old Mar 19, 2015 | 05:01 PM
edge04's Avatar
OE sprockets. So that is what I thought.
Old Mar 27, 2015 | 06:46 PM
edge04's Avatar
installed cam and checking PTV clearance.
would the maximum clearance be when the piston is at TDC? My clearances were 100 thousands on the intake and 125 on the exhaust at this point. Well those are where the valve hits the piston. I'm just wondering if those clearances will get tighter during the engine rotation? Or am I good to go?
Hope this makes sense as this is new to me. Thanks
Old Mar 27, 2015 | 10:57 PM
CAMSTER's Avatar
I rotate the engine to get a full four stroke to get the full picture with a little oil on the valves to keep it from picking up the clay.
Old Mar 27, 2015 | 11:24 PM
edge04's Avatar
I didn't do the clay method, I used a dial and just pressed the valve down until it hit the piston.
Old Mar 27, 2015 | 11:59 PM
03EBZ06's Avatar
I would be more concerned about the timing chain being off than the cam.
What is that crank sprocket degreed at from factory? I would change it!
Old Mar 28, 2015 | 07:22 AM
edge04's Avatar
Now you have me worried. Why or how can the timing chain be off?
I am running stock sprockets. I installed the chain by having the crank sprocket dot pointing to 12 and the cam sprocket to 6 - lined up. This put the cam pin roughly at 3 o'clock. This put number 1 at TDC and I had a piston stop attached.
There was some slack in the chain which I thought could change the cam by a couple of degrees but I spoke with Martin@tick who designed my cam and he said that was normal. I would think that slack would tighten once the engine was running?
Old Mar 28, 2015 | 10:55 AM
03EBZ06's Avatar
Sorry I meant the crank gear itself. Agree with you on the chain. I was more curious if the factory crank gear is zero deg on install. I usually use gears with timing marks on them so that caught my eye.
