440 CI Marine Build Component Selection Help
Looking for some input on components for a scratch build I have been researching for some time and am about to move forward with. Will be working with a builder and machinist but my experience is with old school BBC and SBC so trying to get up to speed on LS stuff and educate myself proir to the build. Basically looking for opinions from the guys on here who are already running the stuff or better yet have broken it lol.
The goal of the build first and foremost is to have an engine that will live at extended high RPM and load use, with the power levels I am looking for. Going to be an iron block, aluminum head, carbureted, hydraulic roller engine. Thinking 4.185 bore x 4.00 stroke as of now, 6500 RPM target could stretch to 7000 if needed, looking to make 650-700HP NA, pump gas. Will build bottom end to handle forced induction down the road so build for 900-1000HP. Looking to use good components but nothing exotic or extravagant.
Block wise I am pretty much thinking Dart LS Next for the extra sleeve length and less hungry oiling system. Don't see a lot of other options in iron other than the lsx piece.
Crank, rods and Pistons I am still researching and would like some advice. Are the overseas forgings such as Compstar or K1 ok at this level or would you go to the mid level US stuff? I like to go US made when possible not sure how much $ is involved to do so yet. Pistons seem to be pretty close price wise between Wiseco, Diamond, JE etc any one better for the $?
Another question would be compression ratio, with a good aluminum head what is a safe number for extended RPM operation at 91-92 octane?
Heads, I am looking at either some worked on LS3 heads or going up to AFR 245's or Dart Pro 1's. Any thoughts there or thoughts on cathedral port vs square? I hear cathedrals carry more torque down low and if so would be an advantage.
Valvetrain, upgraded GM rockers or aftermarket? Have not heard much good on the aftermarket stuff. Springs etc will be speced to match cam.
Intake will probably be a super Vic or Vic jr, will talk with Pro Systems on carb.
I know this is kind of low tech but it's already wordy so apologies, please feel free to expand on anything and advice or input is much appreciated.
With a Hydraulic Roller and stock rocker arms. USE the STOCK CAST IRON EXHAUST MANIFOLDS. Sounds simple but will make for a helluva combination.
If you plan to go forced induction I would go EFi from the start. A stock iron 6.0 block and a forged crank will go a long way 1000hp+ with just about any cylinder head and boost plus stock intake.
Is the engine bay enclosed or open?
Look into a $600 take off LSA (Cadillac CTSv) blower all over eBay and do a built bottom end for that. With your unlimited cold water source the intake/intercooler would never heat soak. 700Rwtq at 2000rpm would make for a wicked boat.
If you have to have an ls go to the LSX block. I see the Dart as another step in the wrong direction. A 434 can make 700fwhp. A solid roller should be a must as it gives the most control. They also will last longer in that environment. Cathedral ports are more responsive in a car but a boat doesn't load the engine like a car does.
How much is this boat going to weigh ?
Cylinder heads...... you mentioned torque. You'll have that anyway you go on heads with a 4 inch stroker crank. For max torque down low the cathedral head is king. The LS3 rectangle port doesn't really start breathing and getting the job done to 4500 rpm or so but then again the CAM has to be on point no matter which head you choose. With a big bore build you have all kind of head choices. No one here mention using a LS7 head which in my opinion is the best bang for the buck. I personally like the LS7 head over the LS3 head as far as factory head goes. It's plenty of head porters that can get those bad boys flowing over 400 cfm!!
Good luck
Also 11+ compression isn't going to like boost later, so either build it for NA power, or build it for boost. Cam choices, etc are going to be vastly different.
