01 SS M6 : LS2 447ci | MMS 250cc ::: (Mamofied Top-End Arrived)
Old 02-25-2016, 03:42 PM
  #81
mchicia1's Avatar
On the pushrods..
When you order pushrods, aren't most companies advertising with gauge length? You measured end to end. What pushrods did you order?
I used my regular comp pushrod checker with my johnson lifters and didn't have any issues. One turn is .050 yes, but that also means half a turn is .025, so you can still get a pretty close measurement with that tool.
The only better way I see is using your tool, then sending that directly to the pushrod manufacturer.
Old 02-25-2016, 03:50 PM
  #82
LS1Tech Sponsor
Tony @ Mamo Motorsports's Avatar
Originally Posted by mchicia1
On the pushrods..
No need.....you simply measure them from end to end with an 8 or 12" dial caliper. That's the best and easiest method to get accurate results. Counting turns is hack in comparison and you can get the tool you need from Harbor freight for under $50.....it will come in handy for other projects
Regarding the clutch this is a really good thread highlighting the Mamofied RPS BC2 Clutch....it IS the ultimate clutch you will ever install in your vehicle.
https://ls1tech.com/forums/manual-tr...ll-review.html
Im goint to have to source Mamo Motorsports valve covers from Mahdi......they look great....he took that project on all himself and just surprised me with the results recently!.....LOL
Cheers,
Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Old 02-25-2016, 04:01 PM
  #83
Cold Zero's Avatar
On the pushrods..
Yes the "ready to go pushrods" are gauge length.
With the tool I used, I measured them end to end and Tony Mamo custom order them from Manton Pushrods.
For regular Comp Cams pushrod checker, I was using it before when building my old 347ci. But truly, you cannot guarantee 100% that the position you choose for the checker will not change (flip a little by your hands when install), during the installation/removing of rockers or removing the checker to count the turns.
Not to mentioned that the 0.025" is not considered to be "PRETTY CLOSE MEASUREMENT" in mamofied builds Tony is very serious when it comes to valvetrain.
It might be easier with stock rocker. But with aftermarket rockers like what I have, It will be impossible to adjust the checker while the rocker is there. You need to remove the rockers for every check. Not to mention that Tony requested to check all the 16 pushrods. Not bad if you have a red Marlboro lol
Old 02-25-2016, 05:00 PM
  #84
Cold Zero's Avatar
Cheers,
Tony
Time for you now to open a forward mailbox in Saudi Arabia .
In the attachment some .PNG pictures to help MAMOFIED members with their covers, stickers and photoshop works.
Attached Thumbnails 01 SS M6 : LS2 447ci | MMS 250cc ::: (Mamofied Top-End Arrived)-logo-vc.png   01 SS M6 : LS2 447ci | MMS 250cc ::: (Mamofied Top-End Arrived)-logo.png
Old 02-25-2016, 09:38 PM
  #85
mchicia1's Avatar
How do you order pushrods that are measured in gauge length like off the shelf Trends? I am curious, because I have no problem spending $50 for more accurate pushrod length.
Edit, just saw they are custom ordered Manton.
Old 05-19-2016, 06:43 AM
  #86
Tuskyz28's Avatar
Wish the thread will come back alive with some dyno numbers or a video or something.
Old 08-14-2016, 12:12 AM
  #87
Tuskyz28's Avatar
Or maybe not..... damn!! What happened?
Old 08-14-2016, 01:10 AM
  #88
DavidBoren's Avatar
Hopefully he is having way too much fun driving this beast to post. I am quite curious as to how this turned out. A lot of quality parts went into this, it only seems that we could expect some pretty awesome results.
Old 09-22-2016, 01:33 PM
  #89
ALPz28's Avatar
Update this!!!
Old 06-18-2020, 12:52 PM
  #90
bortous's Avatar
Any updates here??
Old 06-19-2020, 12:58 PM
  #91
LSXCamaro4Life's Avatar
Nice Build.
Old 06-19-2020, 01:50 PM
  #92
Received 3,050 Likes on 2,375 Posts
Originally Posted by bortous
Any updates here??
After this long, I highly doubt it.
Quick Reply: 01 SS M6 : LS2 447ci | MMS 250cc ::: (Mamofied Top-End Arrived)
