Which cam for 408ci stroker with ported LS3 top end ?
Well, I have a 241/251 from FTI that I had in a 404 with a stock LS3 top end that made 503/470 at the wheels for sale.
Less than 500 miles on the stick if interested.
What was the lift and LSA? And sorry but not interested in buying another cam right now. When I do or if I do decide to purchase a new cam after I get this girl up and running I will most def be giving Martin or Pat G a call for a custom setup.
One time cam...
I would put those you have for sale and contact Patrick G do it rite the first time save a lot of work, those cams you have are real nice they should go quickly.
Just decide your shift points, if for street 6,700 should be max for a good idle and brakes vacuum with a good intake manifold.
I figured I would give it a shot, but after reading through your posts again, it isn't the cam you are looking for anyways.
Thanks Speedtigger.
Anyone else have any other thoughts. I have both of these camshafts so just trying to decide which one to stuff this engine with. They both have aspects that I like. I just wish the 2nd choice cam was on a 110LSA and I wish the intake duration on the 2nd choice was around 240 or so. That's why I will eventually go with a custom cam from Martin or Pat G if I am not happy with the way these cams I have right now make the power the way I am looking for. I'm looking for good power under the curve and torque and descent top end. I don't care about what the peak HP numbers are even if they were 700hp if the lowend and power under the curve were garbage. Thanks for the input and keep it coming.
Keep in mind that the LS3 heads hate overlap when it comes to street driving. So, the more overlap you have, the more bucking and surging you are going to get in the 1500 - 2000 RPM range due to intake reversion. It is why I took out the 241/251 on a 112 for a 231/239 on a 115. I went from 22* of overlap to 5* and the street manners improved tenfold.
Location: Coast of San Mateo County Between Pacifica & HMB
Muh Thugga
Reversion refers to gas, reverberation refers to sound.
I do like your 231*/239* 115* LSA recommendation!
OP
I would still have Kip or Pat G spec a cam
and as said sell the 2 you Have!
OP
Ok. So anyone else? Between the 2 cams posted? Any experience with similar setups? Like I said if it doesn't make the power I want and where I want it then I will be going with a cam from Martin or Pat G. But until then the choices are the 2 above. And remember these intakes supposedly only make power to around 6500rpm or so
The 241/251 had a 109* intake centerline. I will have to find the cam card for the 231/239.
EDIT: The 231/239 is on a 112 ICL.
1st post "purely a street car" the street manners vs driving it down
The 1/4 1X Yr is not even a consideration for a cars daily enjoyment.
Mug Thugga has given not only personal driving experience but
Data to back up his point. Very valuable knowledge!
I do agree that the conversation does become about overlap, and a lot of people overlook overlap and concentrate solely on duration and lift numbers when selecting a camshaft.
