Ls3 418 hates the street Help
And cubic inches do make a difference. Read the vacuum of the same cam in a 346 then put it in a 418. You'll gain like 3-4" of vacuum. That means you can use a commensurately larger cam to end up with the same vacuum as the original cam in the 346. It just so happens that around 8 degrees is what it typically takes per 50 cid to equalize the vacuum reading.
As others have said. If your cam isn't doing what you want it to do, your tune is off.
And if you have a Gen IV PCM, there's no reason it can't compensate. I'm working with a slow *** Gen III PCM with an IAC...
Recently I switched intake manifold to the Holley Hi-Rise, new intake setup and larger injectors for e85. So I can keep you all posted if you like on how my tune is working out with the recent changes.
When VE and MAF tables are correct then PE should bs set to the correct fueling (about 12.5-13.0 for NA).
With the E38 it's difficult to hit the airflow limit, so P1514 indicates you have to edit the airflow/throttle sanity table(s).
