Cam info for Kip...
http://www.enginelabs.com/engine-tec...ild-with-ffre/
What do you guys think of the LS7 265cc 4.065" head by Mast? The tech there said they were killer heads.
The Mast heads are all very beautiful to look at. I have seen them at PRI and LSFest. I have never used them personally, but the LS7 platform is very attractive if you are starting from scratch.
This setup has to go through 2 tests before any changes can be made.
1. Initial track test. 2. another intake.
I had Paul flow these next to a stock LS3 head at PKRE. They outflowed a stock LS3 head back to back on the same bench about 15-20 CFM up to .550" where the factory LS3 head started to get noisy at which point the Dart Pro1 LS3 head pulled away by about 40 CFM or so to .700" and beyond. Paul Klyczek said the port looked really good to him and the only thing he might do is a custom 50ish degree valve job for what I was trying to do. But, I left them stock.
Wonder what those Darts would do with a CNC.
thats what I thought about the head, the best. still looking for an example of a car that has my heads though. crossbreed has exhaust and intake work on his.
My heads are out of the box except for whatever was needed for a intake port match and they have TEA's nitrous exhaust port.
Oh and they were milled which should kill numbers , not help
Maybe you should ask me about my heads instead of asking others
Sorry but im going to sit this one out from here on out , and see how it all plays out.
I feel like all I did was try to show you the heads can be made to work and now im the bad guy.
Good luck
And if you're still not happy why not have them worked over?
Also what power did your car make before?
Good luck
I was only trying to point out that our heads are not the same. If I mod the intake port or exhaust at this point surely TFS will claim it was done wrong.
