Cam info for Kip...
How about sending a copy of the graph without the numbers, just cut and paste out the RPM part. Did you mean the car revs to 7400 or peaks at 7400? Just not seeing it w/those heads---at least not yet.
Ther'es faster stuff out there than mine for sure. Ill get mine figured out someday
Good luck
Just my opinion.
KW
Both my TFS235 and my friends MAST245 engines were into the 6000+ rpms on peak.
crossbreed claims 7400rpm peak, thats 1600 more rpm. Even my old HR was shifted at 7200 for best ETs. If I gain 500rpm w/the Mast, Kip better get a UPS shipping label ready.
KW
https://ls1tech.com/forums/dynamomet...ke-500-hp.html
https://ls1tech.com/forums/dynamomet...i-results.html
https://ls1tech.com/forums/dynamomet...whp-520tq.html
https://ls1tech.com/forums/dynamomet...o-results.html
https://ls1tech.com/forums/dynamomet...ers-build.html
The links below are from the 'Dyno' thread'. I don't think any of these heads are TEA TF 245's, but all of them are cathedral port heads (with smaller intake ports) that peak right about 6500 RPMs. I can see no reason why your engine shouldn't peak at LEAST at the same point.
I am not arguing "cathedral ports", even my last TFS235s were in 6200-6400rp range, about what I would expect. In case you weren't following, on the EXACT SAME engine I took the 235s off and put the 245s on, good bye rpm and power. I attributed that to 11.5:1 compression and maybe bleeding off compression. One cylinder at the time was known to be a little low. So heads sucked right from the start. Once I rebuilt the engine, good compression and leak down, to 13:1 same results. Just the facts.
The car is going to get raced not this weekend but next, so I will post up and we will follow this problem to success.
What??
A cam only ls7 car making in the mid 500s will go into the mid 130s all day..
I've never dynoed over 600rwhp and have plenty of mid 130s traps on older motors/setups.
Overall, its not looking good for the heads. Testing current setup this Saturday.
