ls7 434ci low power!!!
I believe that your cam isn't a good match for your cylinder heads and compression ratio. Personally I would like to see more intake duration and a split of about 15 degrees with the exhaust, more lift and a tighter LSA. I think you could easily pick up 30-40 more HP with a better cam when combined with the exhaust system below. Next, your headers are too big, the 2" primary is likely costing you 12-15HP over a good 1-7/8" header and preferably a stepped 1-7/8" to 2" header. If you got a stepped 1-7/8" header and specified a 3-1/2" merge collector with 3-1/2" head pipes you likely would pick up an additional 25-30HP over your current exhaust system.
I agree with Tony that your intake system is likely begging for an additional 20HP with his trick ported manifold.
Add these up:
Cam: 30-40HP
Exhaust: 25-30HP
Intake: 20HP
You're looking at an opportunity of 75-90RWHP which would put you in the 670-685 range!
Thanks for helping me
About the camshaft Who would you recommend for custom camshaft or do you have a camshaft spec
I will try to change the headers and the intake manifold , but they told me you need 2 inch headers because you have a high compression engine 😅😅
My 454 had 2 to 2.125 with 3.5 merge. Played with length and found a little top end et.
Tim
And for those that don't believe installing the "wrong" size header can cost you power here is an excerpt from an unsolicited e-mail that I received from a fellow enthusiast a while back who swapped 1-3/4" headers on a 434" motor for 2" headers and I quote from the e-mail
As we all know (or should know), it's all about maximizing the combination, not just selecting individual component pieces and hoping for the best.
On another note dynos are just for tuning and at 590 plus at the tire I'll Boston
e more interested in seeing your trap speed at the track. It tells the real story. You have a respectable number at the tire there. That's roughly 700 horse at the crank!! Some larger 454 LsX motors don't even make that.
Pretty sure Jared went 8.82 with stock Ls7s. Who did the cam?
I would go with custom camshaft that will give you an optimal DCR to make more power with Q16.
If the cam that is already installed is one of these (off the shelf), then that's your problem. I think those cams were grinded to be used with 11~12 SCR and give you power for pump gas DCR.
IVC is a bit early, but the EVO event is killing a ton of power. It could use a bit more overlap too IMO.
When you have such high compression you are applying MUCH more leverage to the piston early on in the power stroke. A high compression engine puts much more work to the piston in fewer crank degrees than a low compression engine. A high compression engine also drops cylinder pressure faster than a low compression engine.
This necessitates a much earlier opening exhaust event to utilize the additional cylinder pressure instead of waiting later to open the exhaust valve and robbing top end HP.
There could possibly be something going on in the valve train at high engine speed based on how the graph looks a bit wavy, but that could also be timing and fueling causing that.
It could have a valve control issue, but normally it shows up in greater fashion than seen on this graph.
I can say this though, the EVO event on that cam is at least 10 degrees too late.
Add these up:
Cam: 30-40HP
Exhaust: 25-30HP
Intake: 20HP
And for those that don't believe installing the "wrong" size header can cost you power here is an excerpt from an unsolicited e-mail that I received from a fellow enthusiast a while back who swapped 1-3/4" headers on a 434" motor for 2" headers and I quote from the e-mail this person lost 25 RWHP and 30 RWTQ!
