LSA crate break in
1915: Fokker flight crews pre-heat castor oil on a stove before filling the crankcase.
1970: Bill Jenkins suggests hooking up water lines from your push truck to your new race engine.
To restate (for all those looking at installing new or rebuilt engines) .....simply......running the engine hard from the onset as a means to breaking it in, is not the way to go.
But then....it's your engine....it's your money.
KW
With at least 1200 PPM ZDDP (Zinc & Phosphorous) for Ring Seat.
I use AMSOIL Break-In Oil.
I use Joe Gibbs...... http://shop.advanceautoparts.com/p/c...ntent=10202663
KW
Also I found when dummying the pan, one of the windage tray bolts cuts into one of the steel pressure lines to the filter inside the pan which might have some affect.
I'd appreciate any info you can give me?
Mine has been swapped to a front sump (GTO) pan.
Also running accusump so I'll keep an eye on pressure drops on that.
