416 Heads
Old Mar 1, 2016 | 10:02 PM
03EBZ06's Avatar
Default 416 Heads
What do you guys think. Looking at MAST 265CC LS7 heads
and GM LS9 276CC heads. I think I know what to expect from the MAST heads, but haven't heard much of the others. They are cheaper, not sure about power output though.
Old Mar 1, 2016 | 10:25 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
May I offer another suggestion for your consideration.
Tony Mamo Ported TFS LS3's
300+ CFM @ .300", 350+ @ .400" 380+ @ .600"
all from an Intake Port less than 260 CC and a
Much better E/I Ratio!
Old Mar 2, 2016 | 12:53 AM
03EBZ06's Avatar
I have always been a fan of his stuff, so recommend away!
Old Mar 2, 2016 | 10:54 PM
FRiCK's Avatar
Your combo is begging for some of his handy work!
Old Mar 3, 2016 | 12:03 AM
Strokedcamaroz28's Avatar
brodix here
Old Mar 3, 2016 | 12:45 PM
Rise of the Phoenix's Avatar
If you haven't already, take a look at this thread. Lots of information pertinent to your build.
https://ls1tech.com/forums/dynamomet...l-results.html
Old Mar 3, 2016 | 12:48 PM
KW Baraka's Avatar
Tony Mamo Ported TFS LS3's.......
Aww man.....I gotta give Tony a call. I didn't know he did rectangular ports!
KW
Old Mar 3, 2016 | 01:44 PM
tadams72's Avatar
KW
Yep. Got a set on my 427. Tony is top notch!
Old Mar 3, 2016 | 01:54 PM
blk00ss's Avatar
I still think you have some of the best heads out there... My 235's made 571/535 with a unported stock fast 92 and PTM 92 lol. Stick water pump as well. IMO you're crazy if you don't at least try them again with a engine that's healthy.
Old Mar 4, 2016 | 05:20 PM
Jimbo1367's Avatar
Never seen claimed @ .300" #s that high before.
Old Mar 4, 2016 | 09:45 PM
Wow thanks for that catch Jimbo!
My apologies!
The .400" should have been 300+ CFM
The .500" should have been 350+ CFM
The .600" was correct @ 380+ CFM
These were on a 4.125" Bore.
Old Mar 5, 2016 | 04:28 AM
gnx7's Avatar
Well. My shezzy noticed the airflow! Jk. Run with it!
Airflow is king !
Old Mar 5, 2016 | 10:18 PM
BOLO's Avatar
OP, which heads did you end up getting? I hope you chose the ones I like,LOL.
Old Mar 6, 2016 | 02:09 AM
03EBZ06's Avatar
I'm ordering Monday and it looks like the MAST 265CC LS7s.
Old Mar 6, 2016 | 08:45 AM
BOLO's Avatar
Sounds good. Talk to Chris@MAST.
Old Mar 8, 2016 | 03:27 PM
03EBZ06's Avatar
Can't get em to answer the phone. Wtf
Old Mar 8, 2016 | 07:18 PM
tadams72's Avatar
Call Tony Mamo at Mamo Motorsports. He's a magician with getting heads to flow and make big power. AND he answers the phone!
Old Mar 8, 2016 | 08:26 PM
BOLO's Avatar
Did you try leaving a message for them to call you? Chris is usually prompt on getting back with the calls.
Old Mar 8, 2016 | 08:40 PM
LOL! What He Said!
