Project LS-FR33 [Warning: PICS!]
-I pulled the pilot bearing and inserted a new one at the correct depth this time
-Wilwood 6 piston big brake kit with 14", 2-piece rotors (I was going to do the 4-piston cheap CTS-V/Vette Brembo upgrade, but they will not fit behind my wheels)
-Got my BBK header welded up and re-ceramic coated
-Header, coil packs, wires installed on passenger side too now
-Dipstick installed
-New radiator overflow hose
-Breather tube to passenger head routed
-I pulled a newer 2002 gas tank at the junk yard only to find that the fuel was drained out by drilling a hole in it, so I had to leave the tank. I pulled everything I could off of it though. Not pictured, I also got some manual pedals for the swap.
-New upper A-arm suspension brackets, spring perches, and those plate things that sit inside the spring perches
-Prep to stop rust under shock towers. Clean, scrape, wire brush, rust converter to change iron oxide to iron phosphate, paint coming soon...
Better still, the giant calipers are actually 2.5 lbs lighter than the stock ones when the brackets are factored in. So some gain in rotational mass and inertia (due to the mass concentration away from center), but a net loss of 2 lbs. unsprung mass at each front wheel. I was certain that this kit would add a lot of weight, so that is a nice surprise.
-Repair of the rusty underside of the shock towers is completed
-My first attempt at rear urethane bump-stops (originally meant for a Jeep). They were too stiff, so I drilled holes in them. Still too stiff, so I drilled more holes. They worked well after that, but as you can see, they were slowly getting torn apart. Luckily these are less than $20/pair.
-New urethane bump stops customized with a window instead of perforation holes
-Used fuel tank cleaned up and matched with parts I pulled from the first junkyard tank
-Racetronix fuel pump was NOT compatible with GM's own ACDelco MU1730 fuel pump for our cars. Only the original fuel pump that came with the car will work, or...
-...Fuel pump from the WS6 Store, MU230-RPM, will work after some Dremmel work on the rubber sleeve
-Fuel pump installed in tank with fuel hoses, charcoal canister, upgraded electrical wiring, foam isolators, and filler neck
-Fuel tank installed in car
-Old charcoal canister removed
-Filler neck bracket fabricated
-Racetronix fuel pump relay and ground located (had to custom mount relay, due to 4-channel ABS blocking the suggested location)
-Racetronix dedicated power cables routed along car from engine bay
-Gas/brake/clutch pedals from junkyard car
-Pedals media blasted to remove rust (primer/paint coming soon...)
-Automatic trans console shifter connector cut off
-Reverse light cable run from console through firewall, to engine harness, to transmission (brown and light green)
-Clutch pedal ignition safety switch wired to console connector (purple and dark green)
-Black and orange wires shorted for restored hatch release functionality
-Pedal harnesses routed: Clutch pedal ignition safety switch connector in blue. Cruise control cancel switches for clutch and brake pedals (black) and clutch anticipate to computer (white) on left side.
-Holes drilled in firewall for adjustable clutch master cylinder mounting
I actually got the pedals in (incluing a new brake booster), but the stupid adjustable master cylinder eyelet won't fit over the clutch pedal stud. Once I figure that last little piece out, I will get a photo of the pedals in place. I will probably add some metal pedal covers later on.
-Clutch pedal MC mounted with pedal bracket
-Pedals installed
-Clutch reservoir mounted and connected
-Firewall side of clutch MC. Note that it does not hit the stud if mounted correctly.
-McLeod RST dual plate clutch installed (9.5 lbs. weight savings, and lower polar moment of inertia)
-4 pedals = 33% more pedals!
-Cutting hole for shifter to match lower shift boot
-Test fitting lower shift boot
-Priming hole in console
-T56 Magnum with F-body tailshaft (wider ratio, 2.97-1st and 0.50-6th)
-Clearance issue with slave cylinder hydraulic disconnect. I'll be doing some grinding on the housing shortly.
-Installed remote bleeder clutch line
-The plastic clutch alignment tool allowed the clutch plates to sag under the weight, which caused an alignment issue when attempting to install the transmission. Solution: use the transmission as the alignment tool!
-Transmission installed to engine/bellhousing
-Plastic dust blockers installed in trans/bellhousing
-New starter motor installed
-New header collector studs installed with red Loctite
-Popped off vacuum line plug on rear of intake
-Installed 90 degree fitting on vacuum line to reach straight fitting on new LS3 intake
-Replaced old, cracked and patched vacuum line that runs to vacuum tank by making my own. Note the added electrical tape to protect against chaffing below the headlight.
-MAP extension harness was found to not fit the MAP connector. No one even makes a female connector that would have worked. Solution: hard wire extension to factory harness.
-Cap off and insulate old automatic trans wiring harness
-Pull old brake master cylinder
-Bench bleed new master cylinder
-Strip all brakes and parking brake hardware from rear axle
-The dreaded shock mount defect on the brand new mount means the holes don't line up. Have to take the coil-over completely apart and install a new one.
Basically I just have to take care of the passenger side coil-over and install the Anti-Venom mod to the T56, and the engine should be ready to go back in the car.
Haha, but it could use a few descriptions as I'd guess most are uncertain of at least one thing. Me included on a couple of the wire mods.
I love all the detail work, it's my sort of thing.
The wiring is modded for one of three main reasons: 1) The newer 2001-2002 ECU swap, which is just the two main connectors. 2) The automatic to manual swap (shifter, pedals, trans connectors) or 3) The LS1 to LS3 swap for sensors. There will also be a few little mods for the upgraded/dedicated fuel pump power and the electric water pump. Which of the wiring images did you want to know about?
No you ran some speaker wire in through the firewall and connected it by the shifter, I thought. I wasn't sure what that part was about.
After the first page I never read one word. Not that I like to read, I prefer the pictures, but I think I was scrolling so much faster I couldn't even notice any words that weren't a large paragraph.
-The "Anti-Venom mod" to soften shifts with the MGW (washer not pictured)
-New A/C condenser will fit, it just looks way different from the old one. Think the black one is original?
-ENGINE IS IN THE CAR! K-member and trans cross member bolted in
-Connected ground cables at back of driver side head, vacuum line at back of intake, and cam, oil PSI, and MAP sensor electrical harnesses at the back
-There is even clearance for the acoustic intake cover. I had heard this would not fit...
While I did not blueprint the rotating assembly, I did take the parts to a shop where we weighed everything. If you notice in the crank pics, there are some very large holes drilled in the new crank as I had it balanced to match the new internal parts.
-Used the starter block-off plate as a wire loom guide for the relocated knock sensor
-Knock sensors wrapped with metal tape to protect from headers
-Chassis-Block Ground Wire Part III - Third time's a charm. The factory ground wire broke years ago. The first one I made was too thin IMO, so I made one from 10 gauge. It was too short, so one last time...
-Power steering rack looks like it might have a crack in it. I hope this is just a casting line. I will be very disappointed in TurnOne if they shipped it back to me broken.
-Fuel Injector and other Wiring getting connected to top end
-New Battery Cables
-New 3-Core Champion Aluminum Radiator
-New Condenser
-Grinding lower radiator isolator to fit bigger radiator without plastic end tanks
-Clearancing fan shroud for electric water pump and thicker radiator (which pushes the fan shroud rearward)
-New Upper Radiator Support Bolts
-Alternate upper radiator hose spec (Dayco 71668 D-code) to fit electric water pump outlet relocation, cut shorter, plus lower hose shorter
-Trimmed upper shroud to clear new rad cap and FastToys intake
-Radiator hose adapters for steam port and larger overflow tank hose fitting to fit factory hose
-New Brake Master Cylinder installed on New Booster
-Fabricated Intake Tube to Connect Airbox to Throttle Body (Used silicone to create a seal between 103mm airbox cover and 4" aluminum tube, trimmed tube length, trimmed 4" double-hump hose to throttle body)
-Course Honeycomb MAF Screen Installed
-MAF and wiring adapter installed, I think I will hard wire this later, as the wiring is kind of a mess
-20A Fuel Pump Fuse mounted underhood for RaceTronix dedicated power line
-Remote Clutch Bleeder Mounted Underhood
I've looked at other TAs a few times, and while many lack some of the rust, they always have other problems like severely cracked interior plastics, poor maintenance, or mods that are either stupid (20 holes drilled into the trunk metal for "speaker grounds") or illegal (offroad pipes with no cats). I eventually decided to stick with the known-quantity that's been good to me all these years.
