vvt big or small cam ly6
Old Jul 6, 2016 | 08:53 AM
91Camaro man's Avatar
Default vvt big or small cam ly6
hello all ,
I have a ly6 (6.0l l92 heads) going in a 2800 lbs Datsun 280z.
my qeustion for everyone is. I'm looking for a vvt cam for my engine it'll be a daily driver in the summer mounths and see the track a couple weekands a year.
I'm just not sure wich way to go for a cam. either go with a cam that's a little big for my combo if it were just non vvt and advance the cam timing a lot to compensate for overlap or get a cam that u would usually spec for a non vvt engine and retard it a lot to get a better top end?
Old Jul 6, 2016 | 09:21 AM
Jimbo1367's Avatar
Contact Pat G. HE has a proven record in specing cams. He has custon VVT too.
Old Jul 6, 2016 | 10:35 AM
Tuskyz28's Avatar
Pat G is awesome as stated above....
On the other hand tho Mast Motorsports have a small VVT cam designed for the LY6 engine made to produce 510- 525 at the crank. Specs are 210/230 with less than 580 lift. With a lift like that it'll last forever with a good aftermarket double springs.
Old Jul 6, 2016 | 01:15 PM
I couldn't find the cam on mast Motorsports but I did find one on EPS 218/232@.05 .563/.575 lift on 114 lsa rpm of 2,000-7,000
this seems like the smaller cam option I was looking at along with smaller lift so there's not so much pressure from duel springs on the cam phaser so it can stay accurate at higher rpm.
also I have talked to a couple different venders and got different opinions. I guess I was looking for people who have a vvt cam set up and had to tune them. how ruff the car idles or how tunning smoothed it out and no surging etc.
but thanks for the replies they have helped.
Old Jul 7, 2016 | 03:51 AM
casias's Avatar
When I put my LY6 in, I really wanted to exploit the benefits of a vvt cam. But the larger the cam gets, the less benefit there is, because the phasing has to be limited. The VVT cams are going to be limited to the .560 220 mark, which is fairly mild for an L92 head 6.0.
On the other hand, a non-vvt cam in the .580 230 range will give plenty of HP without any bottom-end loss.
So, I swapped it out for the simplicity of a non-vvt cam and haven't looked back.
Old Jul 7, 2016 | 06:25 AM
Jimbo1367's Avatar
IIRC, Mr Patrick G did a VVT cam with lift north of .600" I really suggest doing a SEARCH and contacting Mr G. He may or may not recommend ditching the VVT based on your goals. Don't settle for a off the self cam.
Old Jul 7, 2016 | 09:13 AM
after reading more on the cams and reading your post casias I'm kinda down to 2 different cams.
either delete vvt and get the BTR stage 1 turbo cam with the easy lobes and use btr platinum duel springs and pushrods. or see if I can get the BTR truck cam stage 3 on a vvt grind and just have to get btr ls6 springs. seems like the BTR truck cam would be perfict with stockish lift at .553" and use stock springs seems like it would work great with the cam phaser extending its life and not beat up lifters either.
Old Jul 8, 2016 | 09:17 AM
also with less spring pressure the cam phaser would be more accurate
Old Jul 14, 2016 | 09:30 AM
looking at my build more with it being a manual I think I might stick with a non vvt cam. also I'm prolly going turbo in the future and need stiffer springs. the more I read about vvt the more it comes to me on why in theory they only put vvt in automatics. my thoughts are in a manual the crankshaft takes a lot of shock and by doing so yanks on the timing chain then has a good chance of retarding the cam phaser against the load. this is most likely made worse at lower rpm that you don't have full oil pressure to manipulate the cam phaser as well.
