Buying an LS3 crate engine, looking to lower the compression without bottom end mods
Whether this will hurt you significantly depends on the volume of squish lost and the distance from the top of the piston to the head.
Too much gap will definitely hurt you. It becomes sort of a dead area until the piston moves down and so may promote detonation.
I don't know what the LS3 combustion chamber looks like, if it is a closed chamber you may want to swap heads to an open chamber design.
I wouldn't touch the heads.....and I wouldn't worry about compression, either. But I WOULD suggest a professionally spec'ed cam that will work, 'as is', with the stock LS3 engine.
Either that, or......
KW
Guys have made 1200 flywheel on unported Cathedral heads that flow 20% less. I'm not sure where you're struggling with doing so on LS3 heads.
Adding boost doesn't increase CFM. You flow the exact same CFM at an increased pressure. If the heads aren't a restriction N/A, they aren't a restriction with boost.
Just that I haven't seen stock heads at 1000+ HP at the wheels.
Although, admittedly, I don't pay much attention to FI applications since I have zero plans to ever go that route.....
KW
There are probably a hundred cars making 1000+ HP on stock castings. I take it you don't frequent the Forced Induction section very often LOL.
My point is, if a 4-cylinder can make 1000 HP on a 300 CFM ported stock casting, then a V8 can easily make more with TWO 320 CFM stock castings. I don't understand the notion that you have to have absurd head flow numbers to make power, which exactly why I scoff at anyone who drops $2k on heads for their 400whp N/A combo. I have 1800 in my turbo setup and I've TRIPLED the power my 5.3 came with from the factory and I'm going on my 2nd year of beating the hell out of this thing on 20+ PSI.
Stop wasting money on things that don't need it. There are guys spending $2500+ to swap out their LS3 heads. I've made over 600whp with a big block that had aftermarket heads with STOCK LS3 flow numbers. You're all insane......
It seems that there's a .04 thickness difference between LS9 and LS3 gaskets, will that even register .1 in a compression drop?
If you're building it for boost, why not start with something a little better suited? You're going to dump money into an LS3 crate only to immediately void the warranty, and your goal is well within ANY gen 4 rod equipped LS engine. Not to mention you're handicapping yourself with the compression.
It seems like you're going with the most expensive, worst way to get 700whp.
My last 3 700+ setups were all less than $5k TOTAL.
