Trick Flow 255s. Which cam should I use?
What headers? What exhaust? What intake manifold?
Assuming stock LS3 intake and 1-7/8" headers into some kind of true duals, I would do a cam like this:
230/246 .637/.604 113.5+3.5. So that's in the neighborhood of the Tick Cam (looked after I set the valve events).
But I would almost want to do an LLR with those heads. Grab some Morel 5452 solid roller lifters and some T&D Shaft rockers with PAC1208X springs. And then run this cam:
Cam Motion LLR 236/252 .700/.680 113.5+3.5 LSA-010
The .010" of lash will bring the lift numbers down a bit and reduce duration by about 6 degrees. So cold, it'll act bigger. But as the car warms up, it'll end up driving pretty nice with 11 degrees of overlap.
That'd be a sweet combo.
If you went with a FAST with the shorter runners, I'd change the cam to the following:
234/250 .637/.604 115+4 Hyd or 240/256 .700/.680 115+4 LLR-010.
Heads out of the box with a much better E/I ratio then the
Stock LS3 Heads. Of the two cams listed I would go with the
Cam Motion Cam. I believe +8-10* negative split is the sweet
Spot for those heads vs the 12-16* often seen with the
Stockers. In fact I would suggest looking hard at the
LS3 Stage 3, 226/234, or the Titan 3 LS3, 227/237,
Especially if it is less then a 80/20 Strip/Street application.
My .02
Good Luck & post results.
But staying down around 230 intake duration or less would be my suggestion with whatever you do (hydraulic).
I would definitely help out the exhaust though with an earlier EVO. If you run a 2" header, you can probably get away with a 12-degree split.
But then again, I like a 12-degree split on a cathedral port with a better E/I ratio to begin with.
I like the earliest EVO I can get. It flattens the torque curve out and carries power well past peak. Yeah, it may not make as much off-idle torque or as much peak torque, but it makes a broader torque curve that doesn't die off uptop.
What's the projected use for the car?
What other mods were done to the car (exhaust/gears/etc)?
If trans is a 4L60E, what torque converter are you going with?
KW
My suggestion now that you spend money on the best heads is to get the best cam to work work for both those heads and the combination of supporting parts you have or will have.
What I would do is to have a cam spec to your application only cost you 40. and will do what you want considering shift points transmission type intake throttle body gears weight power goals and purpose.
The cam is the brain of the engine why use a common brain for a custom purpose.
https://www.guerragroup.com/camshaft-help
I only found the GM-ported heads. I had sort of a hard time navigating the site I must admit, so they still might be doing it...
Shoot me an email or give me a call.
Martin@smallwoodracedevelopment.com
864-723-2892
Since I designed several of the cams being discussed, and have made well over 500rwhp several times with SBE LS3's and these heads I think I can get you what you're after.
I have had customers make 515-520rwhp/450-460rwtq with these heads and a 232/250 .629/.612 112.5+3.5.
What's funny is the TEA TFS 255's actually flow LESS air from .200-.300 than a TEA TFS 245. At .100 the 2.165" valve 255's only flow 2 cfm more than the 2.100" valve TEA TFS 245's. Because the flow is nearly identical at .100, and LESS from .200-.300 the TEA TFS 255's will actually want the same OR MORE overlap @.050 than a similar sized cathedral port head.
Almost always a larger valve head will flow more air from .100-.300 than a smaller valve head. Note I said 'almost' always. At low lift the valve is the restriction, not the port. Since the valve is what is in the way at low lift, the more area you create at low lift (by making the valve bigger) the more flow you get due to less restriction. At higher lifts past .25 L/D the MCSA of the port becomes the restriction.
So the more a port flows a low lift the less overlap it needs and vice versa.
864-723-2892
