Ls2 cam suggestions needed-1964 impala
Old May 2, 2017 | 08:11 PM
chitown64's Avatar
Default Ls2 cam suggestions needed-1964 impala
I have a 64 Impala with a 383 stroker/700R4 and 10bolt posi with 355 gear.. I bought an 06 GTO LS2 W/4L65 with 90k miles..Before i put it in the car i'd like to spruce it up a bit-maybe 50hp..This will be a street cruiser with some highway..Going LS for the reliability but still want a little pep..Any and all suggestions will be appreciated.I was told to look at brian tooley racing.-one suggestion was the LS2 STAGE 2 KIT but they werent sure if I can use existing trans converter..another was speed and performance..looking to see whats worked for others classic car applications
REY
Old May 2, 2017 | 08:19 PM
Want a little lope but easy-on-the-valvetrain lobes? Try the Chevrolet Performance LS Hot Cam. 219/228, .525" 112 LSA. Old school lobes, but will sound good and add the power you are looking for.
Old May 22, 2017 | 10:40 PM
chitown64's Avatar
@G ATSMA--can I use the stock converter with the HOT CAM?
Old May 22, 2017 | 10:47 PM
Not sure about that. Some cams, even though they lope a little, might still get by with a stock converter, but that question should go to someone with a little more experience with this cam or others like it.
Old May 22, 2017 | 11:37 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
We have a high lift hot cam. doesnt need a stall. Nice lope. more power than the gm hotcam. 515 with springs and cam.
Old May 23, 2017 | 04:25 PM
KW Baraka's Avatar
Originally Posted by chitown64
.....I bought an 06 GTO LS2 W/4L65 with 90k miles..Before i put it in the car i'd like to spruce it up a bit-maybe 50hp.......
A 90K mile LS2.....do you know the maintenance record of that engine?
If not, I strongly recommend at least a minor rebuild to go with that cam, prior to installing.
KW
Old May 23, 2017 | 04:55 PM
^ He is correct in the notion tha the gto amd tbss ls2s are notorious for rod bearing issues.
If you need a remain,rering, or full rebuild kit we have all of them available for smokin deals better than summit.
Old May 25, 2017 | 11:14 AM
chitown64's Avatar
@tech@WS6store--please send me pm with number so I can call and get details or PM me details as far as cam specs --price of cam with new spring kit and rebuild kit
thanks
Old May 25, 2017 | 11:32 AM
Sent you a pm!
