7,000 mile SBE LS3 eats a bearing....
This actually happened about a month ago and I never posted but, very disappointing. Picked it up about 4 years ago, 0 mile GM crate motor from a vendor. Put a set of TFS 821's and a Tick cam in it, made great power and ran like a champ for 4 years, then this:
Bearing actually managed to roll over the upper half of the opposite shell, never saw that before. Car never ran low on oil but it did have a propensity to lift the nose pretty good when you'd stab it (no bumper stands or anything like that). Really bewildering considering the low mileage of the motor but, there it is. Curious if anyone has seen anything similar to a stock bottom end?
Define "pretty good". You could have starved it for oil during one of those times. Only needs to happen once.
OIL/AIR Flow
Hi VTC, my guess is the same as yours, the nose lift.
One common observation is the location of the "spun" bearing.
When the Oil Volume is LOW, the forward bearings suffer greater than the rear bearings.
This is due to HOT Oil.
When the Oil Volume is diluted by Air, the rear bearings suffer greater than the forward bearings.
The Air will take the easy path and "blow" the Oil Wedge away from the journal.
Just a "guess" for your case.
Lance
Lance
Number seven cylinder was lean and/or hot
Once the detonation smoked the rod shell to the copper, it heats the rod big end and then spins/overlaps the shells
My detonation theory holds true if upon tear down you find other rods where the cap shell looks new and the rod shell is showing copper in the middle
