Re: N/A 370" gen iv internals, forged pistons, input appreciated
Old 08-24-2017, 04:29 PM
Old School Heavy
speedtigger's Avatar
Originally Posted by tech@WS6store
More often than not the reason for the failure is a lifted ring land from not filing the ring gap larger.
The ones that I have seen have melted, cracked or broke a small piece in the thin, fly-cut area of the crown above the ring land.
Old 08-24-2017, 04:56 PM
LS1Tech Premium Sponsor
tech@WS6store's Avatar
They did not have a hard anodized face/1st ring land either. By flycutting you are going past the anodizing in that spot...but no diff from the picture of a fed mogul VVT 4.8/5.3 piston...and look how close it is to the wall
Old 08-24-2017, 06:30 PM
MIKE93SVT's Avatar
Good points from both of you and are appreciated.
After more thought and considering that I probably won't leave the motor together more than two years it may be wiser to run the pistons from WS6store or find some OEM LS2 pistons
The flat tops would raise compression and hopefully be enough. Haven't calculated it without milling the heads yet
If I use those hypers and don't mill the heads, then hopefully the Cam Motion LS3 King Titan cam will clear. Or maybe the LS3 Titan 3 which is a little less aggressive. But they're both advertised as not requiring flycut on a LS3
Here's the Titan King specs
Grind # XA232/365-XA244/355-12.5+3
Hydraulic Roller Camshaft
Maximum Street - Street/Strip - Race
Duration at .050: 232/244
112.5 Lobe Center Angle with a 109.5 Intake Centerline
Lift with 1.7 Rocker Arm Ratio: .621"/.604"
Old 08-24-2017, 06:47 PM
Titan King will fit without milling or cutting with our pistons.
Old 08-24-2017, 08:27 PM
MIKE93SVT's Avatar
I should mention the heads were cleaned up 0.004 when redone
What head gasket do you recommend?
Thanks
Mike
Old 08-24-2017, 08:30 PM
Stock ls3 head gasket.
The clean up wont matter.
Quick Reply: Re: N/A 370" gen iv internals, forged pistons, input appreciated
