4.8 Land Speed Engine Project
Need some information on doing a 4.8 L20 engine build for D class land speed project. Using a 1999 Corvette FRC for the hull. Maximum displacement is 5.0 for D Motor. I have a 30k mile L20 4.8 engine with a Howard cam, Edelbrock dual plane, MSD box, Holley 4150 650. Would to bore .060 for 302 displacement. Pistons and rings are what I see as the biggest issue.
Joe
Joe
I was able to get 3.840 forged pistons (3.78 + .060) with valve reliefs BUT it has a small pin .927 instead of a .945. Manley 6.300 rods have the small pin diameter so I found the match. This makes displacement come out to 302 cu in. Right where I want to be. Now looking for a stronger cam. Considering Crane 1449121.
Joe
Joe
Hi Joe, I USE a 98mm bore OFTEN with Shelf NPR Rings.
I use RaceTec Pistons at 98mm with the cost of a "shelf" item.
Would you like my help ?
Andy Flag won MANY championships (salt) with my help/ECU/tech.
Lance
Lance
I use RaceTec/AutoTec pistons all the time. Good quality and price!
For sustained high RPM you may want piston squirters and certainly a dry sump system.
Steve Demirjin at RED in Oceanside, CA can do the piston squirter mod as well as any/all machine work....
I bought the engine out of this truck with a couple fried pistons and then rebuilt it with a 4" stroke crank to gain 80rwtq+ (441ci). You could probably copy a lot from that build! My friend Chris Coffey at Coffey Fab in TN built it from top to bottom. Kurt Urban built the motor.
http://www.lsxmag.com/features/inter...at-bonneville/
Hi Joe, YES and I use Crower Cams to Regrind YOUR VVT Camshaft Core.
My ECU-882C will allow you to control the VVT Motor, Advance ONLY for best operation is the WAY.
Limiters Required
Lance
Limiters Required
Lance
The C5 Land Speed Corvette engine assembly finally underway. 2015 Chevy Express Van L20 4.8 engine with 23,000 miles. Bored to 301 cu.in. by Jack Merkel Performance, Texas Speed 2.5 ported heads on 799 castings, BTR 33350135 cam, forged flat top pistons, Manley H beam 6.300 rods, Johnson 2116 lifters, VVT eliminated.
I am considering either an MSD Air Force 2702 intake manifold. Is there a better performance choice. We are racing NA this year but will be spraying nitrous oxide next year.
Joe
Joe
Hi Joe, I have customers in Tooele, we ALWAYS run more compression pressure in that area. (your at 9.5 ?)
I also ADD Timing, about 1*- 2*, for the Road Cars that race at the Miller Track.
Lance
Lance
