EMC similar format with *New info & products*
#61
Your on it D as normal. I got 1 I've been wanting to show you also a 8 second pass with less motor than most of the Lsx I've or we've seen.
[QUOTE] This is why I said Blk00ss should or will be close to a 4 second pass... He'll do a 4 sec pass, speak it into existence. BES Nova build a little more info.
[QUOTE]
400 inches in a Dart block. 4" bore, 3.8 crank, 6 in rods 15.8 comp Brodix 12 deg heads, Ron's Terminator home built motor and chassis. 4.86 gear 32" tire and a glide. Goes thru the lights at 7600. Been chasing the converter and believe that when I get it right I can see a little more out of it. This comb was built after I ran 9.30s for years with a 23 deg motor and was told a small block would never go 8s with out spray. I love a challenge...
I am looking for a timing recommendation for the engine in my Nova. It is a SBC on alcohol with the following specs:
414 C.I. SBC
4.125 bore x 3.875 stroke
15.4:1 C.R.
Heads: Brodix 12x12 SP RP with 64cc chambers
Cam: Comp Cams 12-970-9 mechanical roller
Specifications:
Duration at .05 In. 279 Ex. 286
Lift: In .725 Ex.645
Lobe Separation: 108
Intake Center Line 108
NGK R5671A-8 plugs at .035
Moroso vacuum pump T&D shaft rocker 1.6 Int 1.5 Exh
Weight w/driver 2915 lbs
1.76 Glide
8” 6200 stall converter
4.86 rear gear
32” x 14.5” tires
Ron’s terminator
OK thanks. With my old engine the car has 1.19 sixty but so far this motor has only gone 1.24 so maybe advancing the cam will help get that back. Something just seems off as the car goes high 8.70s but only 148 mph.
414 C.I. SBC
15.4:1 C.R.
Specifications:
1.76 Glide
4.86 rear gear
32” x 14.5” tires
Ron’s terminator
All Pro cathedral 4 bolt casting, hand ported by BES Racing engines flow 380's complete ready to bolt on assemblies.
-Victory Titanium intake and exhaust valves, 2.125 intake 1.65 exhaust
-T&D shaft mount rockers with 7/16 bolt upgrade
-PSI double drag springs
-Custom matched nitrous cam spec'd by Tony at BES 279/300 848/885 116.5 lsa billet core
-comp cam elite lifters .842" body
-Mast 2pc EFI intake with fuel rails, cnc and hand finished to heads with a dry nitrous outlet fogger, cam be removed for -$500
very proven combo, on a 416" ls3 block with 12.5 to 1 compression, this top end made BES dyno proven 828hp NA at 8800 rpm. on a .082 jet plate went best of 5.36 at 129, and on a .136 plate 5.12 at 139. on a my 434 short block they went 5.25 at 133 on the .082 jet plate. I got a new sponsorship on a set of heads so this stuff needs to go. Heads only have 35 runs max from new springs and valve job.
#62
I've noticed all small bore ls engines look for around 270+ @ .050 for 800. But we've noticed that for a Long time now. Let me get up..... and go. I've got some new homes to show you D. I'll send you some pics.
#63
Moderator
Received 1,836 Likes
IDK. I really like that 270/284-113+2 cam spec. IMO, that 414, the exhaust valve opens too late. probably why he noticed he didn't make the trap speed he should have. Also, that exhaust lift is pretty low vs the intake lift. Almost like it couldn't exhale enough to breathe in better?
#64
Looking for 800 whp NA, while the HCI are definitely key parts here are a few random thoughts on less sexy components.
Something like Pantera EFI's advanced EFI PCM and tuning would help. Being able to adjust spark and fuel for each cylinder individually would help get the most of the potential.
Likewise at 8,000+ rpm Pantera EFI 's ign-1a coil packs that are designed for extreme applications would help.
Eagle crank? I think a very high quality crank with perfectly indexed would needed to ensure best accurate timing. I think cranks should be carefully considered and checked. I think a high quality crank would merit consideration.
ITB seems like a good choice
Reduced friction with special coatings might be worthwhile like Nikisil on the lifter bores and maybe cylinder walls.
Ideally reducing weigh in the rotating assembly is good. LS7 titanium rods might be worth considering.
Doesn't LPE have Flat plane crank? worth the effort and coat?1
#65
Moderator
What are your thoughts on a Callie crank?
I thought the flat planes were not that great for 4†stroke?
#67
Moderator
Originally Posted by A.R. Shale Targa
More Malaysian hieroglyphics. Mister apostrophe
Ok apparently the quote mark for inches does it too. ****.
#68
The Callies in the white RS was a 2nd from a defunct LS1TECH vendor because it was turned .010 under and it was balanced too heavy for the pistons & rods the engine builder selected. Had to have heavy metal removed. The crank was straight and throws correctly indexed. Machine work was very good. The Callies Compstar in the 99 TA seems to be good too but I'm assuming ERL checked it before using it.
4 inch flat plane probably not going to work out unless there is expert knowledge for that sort of application.
The LPE flat plane I read about was a 3.35 stroke. With a 4.125 bore that crank yields 358 cubes. It is very capable of 9,000+ rpm with the correct valve train. A max bore of of 4.185 and this crank would give about 366 cubes. The hp would be in the details, the heads and intake. Would make a high rpm screamer but might be a little nasty to drive around low rpm.
My friend that built the RS's 383 LS1 suggested a just for fun engine build with a flat plane crank like the LPE flat plane. Some of the parts we talked about to keep cost down. An old LS6 (lower cost) or LS7 block ( better). Used set of Wegner Nascar spec LS6 / 799 / 243 heads that already had titanium valves and hardware proven to make 620 hp flywheel and high ~575's in race car at 8,000 + rpm with LS7 lifters. Adding a solid roller cam better lifters and springs would allow more rpm be a blast with ITB intake to let the heads breath. 700 flywheel seemed possible in theory from about 320 CID.
Adding bigger valves and a big bore ~4.185 bore with a Darton block make more power etc.
Jesel belt drive etc
Sort of a LS take on the high revving solid lifter 327 small block Chevy. I think it would be fun in a Saturn Sky
#70
Darth
My thing is it ran a 8.70 with not a lot. I researched the heads and the entire combo. Very simple with rpm and a glide.
Flat plane crank* is good to rev but most guys with HP prefer the Center counterweight cranks they don't flex as much and makes for a Happier bottom end.
Very Very Costly for just 900 hp or so at the crank.
I've talked with Steve @ RED around 4 yrs ago with the idea of a 4.230 bore. Not worth it to me, Steve said sealing would be crappy. Good idea....though on the lifter bores etc...... Also on the Eagle cranks they're not as good as Callies top of the line stuff ......or Winburg or what ever. But do work in the good hands of a good crank guy. K1 etc.... You guy's are getting over Budget. ITB and all this...Thought it was suppose to be simple and try to remain below cost.. Stroke is needed to help make the HP and keep the RPM down....
I listed those builds because I've research a lot of them and felt the need to put it out there. No reason to just keep it in my Email. Share.
Reduced friction with special coatings might be worthwhile like *Nikasil on the lifter bores and maybe cylinder walls.
#72
Moderator
Originally Posted by HioSSilver
One word......lsx454r
Or was that a word even.....idk
That is a hell of a starting place
#73
The lsx 454r is good starting place.... seventeen-five or $17k think I'm around 13 with labor and assembly. Also I'm starting to think special heads and all this is not needed....
Factory Ls3 or Rowdy heads could and should work just need more CSA for the up in engine size. 400 CFM is not really needed though it may sound good.
#74
458.0 ci this one's more realistic for me
Block 2k Dry resleeve 5.3 4.185 bore
Rods-Crank with balancing and work $1800 to $2k: Houston Engine and Balancing Jeff and Mile High cranks for re harding 4.125 to 4.162 custom stroke Gotta be different LOL.
Pistons & rings $1500-1700 Pistons with customs 1mm/1mm/2mm ring setup and Total Seal gapless rings
Cam & springs $1000 to 1200 Mike's cams are around 500 and depending on lift used for springs?...$500,600 to 700
Assembly $3500
Everything else I or guy's can reuse: intake,heads,lifters,rockers,vacuum pump,oil pan...etc Could send a set of heads out for more CSA that's all. Keep it simple and relatively cheap. Even use the stock ECU reprogramed by Schwanke.
Assembly $3500
#75
Trying to get past this pneumonia bug....Since Thanksgiving day still sick.
Here's 800 to the rear. Guys that been around for sometime may remember this.
David Lazear
810 rwhp and 565 rwtq @ 8800
1.730 hp/cu in
468ci Lsx tall deck block
Mozez Canted valve heads
60mm Cam
Jesel .937 Keyway lifters
Manton 9/16 pushrods
Jesel Solid Body Shaft System
Titanium valves.
Psi springs
Full dry sump system
Beck Sheetmetal intake with 2 dominator TB's
rossler th400
7000 stall
4.56 gears
9" rear end
and slicks.
1.730 hp/cu in
60mm Cam
Titanium valves.
Psi springs
rossler th400
7000 stall
4.56 gears
9" rear end
and slicks.
#76
Moderator
Assembly $3500
Assembly $3500
Those LSX-DR heads ont he LSX454 from GMPP look pretty tasty
#77
Yea till you have to buy Titanium valves and $2k rocker arms. I tried to price them out cheap but couldn't even with G. Goods reference on which heads to use. For a small bore being Lsx CT heads. Valves are moved closer than the DR and cost still came to over $5k
#78
Moderator
That's nuts. Pay to play I guess, but damn
#79
You do and you kinda don't.....RPM and larger engine size. If you have a few cubes and RPM it should help but as I asked you once before how much can 370 to 380 cfm support. If this gets the goal then High End race heads aren't Needed as good as it may sound. I had to come to this myself.
#80
Moderator
I see what you're saying. 370 cfm should support 815, but that means the heads have to be damn near maxed out, which means no more room for moar
