My 6.2 LS7 Project
I got the heads and cam for free, sortta. The heads were on an LSX454 crate engine that was run on the dyno for 10 minutes before I blew the head gaskets and melted the deck between 2 cylinders on each head. So, they were free, but I had to fix them. Richard at WCCH did a fantastic job of welding, decking and valve job on the heads. I decided to use the cam from the LSX454 as well. Why not, it was free. Also, by using these heads, I could use the LS7 intake which I got complete with fuel rail and injectors for $170! This has been the ultimate budget build for sure.
I'll spare you all the build pics, but here's one that proves LS7 heads will fit on a 4.070" bore with the stock valve sizes. It has ~.040" clearance between the valve and bore.
I did decide to turn the OD of the exhaust valves down from 1.615" to 1.590" to gain a little more clearance to the bore.
I'll update it more when I get it finished up. I'm also tackling the tuning as well. I've begun playing around with HP Tuners to learn a little before I get it installed.
Build List:
L92 6.2 Block
Stock 3.622" crank
Stock 6.098" rods
4.070" JE/SRP 4032 Pistons
10.5:1 compression
LSX-LS7 as-cast heads (67cc chambers)
CHE Rocker Arm Trunion Kit
LSX-454 Cam (236/246 @ .050" with .648"/.648" lift and 110° LSA)
Stock LS7 Intake & Injectors
Ported LS2 Oil Pump
Ported GTO Oil Pan
Bad News
2005 GTO Oil Pan Before
2005 GTO Oil Pan After "porting"
LS2 Ported Oil Pump (performed by me)
CHE Rocker Arm Trunion Kit (exceptional quality)
Looks like the oil pump will just SLIIIDE that oil thru!
Those CHE trunnion bushings look like the right way to go. Slip fit on both "sides", making assembly literally a snap! The snap rings that is! lol I could read the directions on your box lid! Good photography!
Nice deals on the heads and manifold! Always good to ease the financial burden!
Best of luck to you man! I'll be watching!
Cole
You are the ONLY other one here that has ever reported a "ported" oil pan's flow path.
This can double oil flow with that result of less heat created.
I have bought "offset" dowels, engine bell alignment, from McFadden Dale hardware.
Would fitment of that item help with your Exhaust Valve bore clearance ?
Will you use Lash Caps on the EX Valve ?
Lance
No. I purchased factory length SI solid stainless exhaust valves. The tip length would have to be ground/reduced to allow a lash cap. I don't think it'll be necessary. I will keep an eye on tip wear though.
Cole
This was the same thing told to me by Chris @ SAM around 6 years ago when I had the idea was told of offsetting the dowels. Later got with ER Racing and he said they fit the .070 over bore pretty darn good just need to watch it as it's close and beleive he posted this on YB on Cole's thread. For guys with smaller bores you need a aftermarket head or weld up the exhaust side for a smaller valve.
The first start is without any programming. Just the original "tune" that was in the car. After comparing it to a stock file, I don't think there was much done to it at all except the timing table. The "while" is from a REALLY low battery after sitting for 3 months.
The video Idle 2 is after a day of me learning all the f-ing tabs/tab;es/etc. in HP Tuners for the first time. I've since calmed it down a little and still tuning the VE table a little more before I tune the MAF table, so it's running in SD for now.
And since I'm sharing car videos, the last one is of our '67 Camaro that my dad and I built. I did the engine for this one also. I know it's not an LS, but it still makes good power, 780 HP @ 7900 and 587 LbFt @ 5500. It's a 15:1 n/a 406 SBC.
not trying to jack the thread but i have just one question, what rod length did you use on that 406 camaro. I built a 5.7" rod solid roller 406 that sang up to 6800 almost 19 years ago and I wouldnt even be able to have a wet dream of a 7900rpm one
thank you sir
