need cam specs have pic
Old Jan 28, 2018 | 06:12 PM
chevellepowered's Avatar
Default need cam specs have pic
searched on internet, i did not find any results maybe someone else might be of help . very much appreciated .
Old Jan 28, 2018 | 08:26 PM
Obviously aftermarket... but those numbers.... the mystery deepens....
Old Jan 28, 2018 | 09:47 PM
S10xGN's Avatar
Comp Cams LSL series:
13019 = 235° / 0.621" @ 1.7 ratio
13021 = 243° / 0.624" @ 1.7 ratio
113° LSA
Old Jan 28, 2018 | 10:07 PM
Nice work Russ! You must know your Comp lobe numbers!
Old Jan 29, 2018 | 02:03 AM
KW Baraka's Avatar
If you don't have the lobe numbers committed to memory and you know where to look, it only takes about 3 or 4 minutes to find this info.....
But of course.....S10xGN is correct!!
KW
Old Jan 29, 2018 | 09:16 AM
Thanks S10xGN very much appreciated !
Old Jan 29, 2018 | 06:17 PM
A.R. Shale Targa's Avatar
RUSS BE LOCKIN' IT DOWN............................
Old Jan 29, 2018 | 09:42 PM
S10xGN's Avatar
Straight from an old 2012 Comp lobe profile pdf! I haven't checked to see, but there are likely newer versions by now...
