Oil Pressure
Old Mar 4, 2018 | 07:37 PM
TNspeed1's Avatar
Default Oil Pressure
Hey Guys,
I have just finished the rebuild of my 5.3 out of a 2007 Tahoe, and I turned it over today without any gas to the engine. I put a cheap sunpro mechanical oil gauge on it to check the oil pressure, but I am not getting any reading which seems odd to me. This is how I have the gauge ran.
The oil pump is a brand new GM performance oil pump. When I assembled the motor I filled the oil pump with oil, but that was months ago. I primed the engine with a pump a couple of weeks ago, and you could see oil up in the heads and on the rockers. My question is this, is there a way to tell if my oil pump is working? Also is the way I have the mechanical oil gauge ran correct? I would like to get this figured out before I fire it up for real. Thanks in advance for the help.
Old Mar 4, 2018 | 08:50 PM
A.R. Shale Targa's Avatar
Barbell in the back of the block ??
Gasket on the back of the camshaft retainer plate good ??
Pickup tube O ring correct?? Several different colors
Old Mar 4, 2018 | 09:02 PM
BOLO's Avatar
Forget about trying to turn over the engine that way. Put some gas in it and start her up. Right then ant there you'll see if oil pressure is present. Don't sweat it.
Old Mar 5, 2018 | 04:36 AM
TNspeed1's Avatar
The barbell is in the back of the block, and I replaced the camshaft retainer plate with a new one. The retainer plate and gasket are one piece. The oil pump and pick up tube came with two different O rings. I tired both when assembling the engine and from what I remember only one would work. I just don’t want to damage the engine after all this work and money.
Old Mar 5, 2018 | 08:46 PM
Frank O'Brien's Avatar
I would take your oil pressure sending unit fitting out of the block and backfill it with good clean oil at least a quart then reassemble your oil pressure set up spin motor with starter spark plugs out you should get oil pressure!
Old Mar 5, 2018 | 08:53 PM
omaha stylee's Avatar
$6 drill pump. $20 hose and hose clamps from menards. Clamp it to oil filter threaded male fitting next to the oil pan. Spin it for 1 min and you should have 25 psi minimum.
Old Mar 5, 2018 | 08:58 PM
TNspeed1's Avatar
I actually did the same thing. I didn’t have the oil pressure sensor in the valley pan when I did it and shot oil oitl
the back of the motor
Old Mar 5, 2018 | 08:59 PM
TNspeed1's Avatar
Frank I will give that a shot! Thanks for the input
Old Mar 7, 2018 | 07:37 AM
TNspeed1's Avatar
Frank when you say take the fitting out of the block you mean the fitting that is in the valley cover, correct?
Old Mar 7, 2018 | 09:13 AM
LLLosingit's Avatar
When turning it over to get oil pressure do you have the spark plugs out? It will turn over a lot faster with no plugs. It's worked for me every time with no pre priming.
Old Mar 7, 2018 | 09:15 AM
TNspeed1's Avatar
I do not but I will sure give it a try! Thanks for your input.
Old Mar 7, 2018 | 09:49 AM
pantera_efi's Avatar
Default Valley Cover Gasket #
Hi TN, do you have the part number of the Lifter Valley Cover gasket you fitted ?
Did this gasket come with "O" rings ?
Lance
Old Mar 7, 2018 | 10:51 AM
TNspeed1's Avatar
Lance,
this is the gasket i used, and it did come with the o rings which I installed as well https://www.summitracing.com/parts/vri-ms19305
let me know what you are thinking.
thanks,
andrew
kingtal0n's Avatar
when I first put 5.3 swap into my car I had the same issue. Spun the motor 30 seconds no pressure. Thought the pump was bad so I ripped motor out and changed it.
Same thing with new pump. It just takes a loooong time for these motors to build pressure. Makes you want an accumulator. Also makes you want to use 100% synthetic 5W-something haha.
OEM pump inside was fine
New pump on using FSM procedure
take the plug outs for the prime, use a good charger to keep the battery healthy. Dont let it drain ur batt.
Also attached a video of what pressure you should see once primed using an OEM style pump.
File Type: wmv
Old Mar 7, 2018 | 10:53 AM
TNspeed1's Avatar
How long do you think you had to crank it?
Old Mar 7, 2018 | 11:02 AM
kingtal0n's Avatar
took at least 20-30 seconds, remember with plugs out cranking speed is fast, especially with a brand new batt. and a charger on it too. So you can't go by time. Its the number of revolutions. If you figure cranking rpm is 300rpm for example, 1 minute would be 300 revolutions pretty obvious right? so it might take like 150 revolutions or something.
I've heard of the pumps being bad too. Owner of Sikky told me it was common, JY 5.3 with bad oil pumps. Which scared me into changing it right away. But it looked fine and took just as long with the new pump so....
Old Mar 7, 2018 | 05:55 PM
TNspeed1's Avatar
Awesome. Thank you guys for all the input and suggestions. I will give them a shot this weekend.
Old Mar 12, 2018 | 07:06 PM
TNspeed1's Avatar
Alright guys I wanted to say thank you. I pulled the plugs and cranked it for probably 25 to 30 sec and it built 30 psi of oil pressure which seems good for it being 40 degrees outside. Thanks again
Old Mar 12, 2018 | 09:51 PM
LLLosingit's Avatar
Your welcome, Glad it worked for you.
