Ls3 NA Build For My Focus
OP, get some proper valvesprings on this thing and give it hell. I am expecting up to ~575rwhp with no other changes. The cam is not perfect for NA, but we don't know exactly how much you are losing due to valvetrain harmonics up top so no point throwing money at it until you get it right as-is. Bowtienut nailed it on the third reply
.You are literally .001" away from the max lift for those springs(.624 vs .625 max!), and the pressures are too low for even 7k rpm (400# open vs 420# recommended for 7k).
Can't wait to see this motor dialed in, its a monster.
...its not only big power cars too, check out this cute little import with locked vs unlocked stall. Its only a few TQ higher in this case, but on that small of a motor that percentage difference is huge:
Also, keep in mind that 420# target is still is likely not enough open pressure for him since that is what COMP recommends for that cam spinning to 7k. If he spins to 7500-8k like his motor will want, he would need higher than that 420#s and he doesn't have the clearance to shim them that much.
The cheapest option would likely be to get the TFS "Option" springs for those heads I listed earlier(TFS-16306-16)...they are ~465#s w/.650" max lift vs his current 400# w/.625" max lift. Note that they are listed at a 1.82" installed height vs 1.8" so if he runs his current keepers and locks there will be an extra ~9#s of pressure.
I ended up installing a set of pac1209x springs today. May be a little more spring than I need for my current cam but I plan on adding 1.8 rockers in the near future and maybe a bigger cam.
I should be able to get it back on the dyno tomorrow. Also I will be running my drag radials instead of the crappy tires I was running last week.
Anxious to see it with a good spring.
. Was exited to see what it made. They are pretty much brand new and unmolested so hopefully TFS does right and exchanges the whole head for you...I would tell them you are uncomfortable running them now and push for exchanging both in case it was a bad batch of guides.
Thoughts?
Where are you.....in Mexico.....or in the states near the border?
KW
Steel......solid......but heavy. But the 1209X's should handle them fine.
KW
I bit the bullet and got a shaft mount rocker set up coming. Also just ordered a custom cam motion solid roller.
So if anyone needs any barely used parts let me know, haha
