L96 Compression
Old Apr 16, 2018 | 10:14 PM
SLWRDE's Avatar
Veteran: Navy
Default L96 Compression
Is there an easy/simple way to bump of the compression of an LY6 or L96 from a 9:6:1 to a 10-10:5:1 or better without having to replace the stock pistons, rods and L92 heads? If the answer is to mill the heads, how much should I mill using this cam 224/236 .600/.600 110 LSA or the Titan 3 from Cam Motion. I know I could buy some flat top pistons and that will do the trick but I really do not want to have to tear apart the lower end, rebalance the crank, and then put it all back together. Nor do I wanted to spend the money to do all of that. I am just looking to bump up the compression with what I have, do a cam swap, and call it good.
Also what head gasket would you guys recommended?
Thanks for all of the help.
Old Apr 17, 2018 | 12:08 PM
ColeGTO's Avatar
First you have to know how much the pistons are sticking out of the block. Once you have that measurement you can determine the proper head gasket thickness to maintain .040" from the piston to the head. Typically this will be a .051" stock head gasket with the pistons .010" above the deck giving you .041" clearance. Once that is determined, milling the heads is the only other way to increase the compression (aside from changing the valve head thickness or pistons themselves).
How much to mill is the question. You'll basically have to mill the heads as much as you need to get the compression you want. Assemble the engine and check piston to valve clearance and then fly cut the pistons if you need more clearance.
You'll be hard pressed to find all your answers from previous builds as each combination is different. Just take it step by step on your own build and know what you have and be certain that at the end of the day you know it is correct and will work.
Old Apr 17, 2018 | 09:11 PM
SLWRDE's Avatar
Veteran: Navy
Cole,
Thanks buddy for all of the great info. It seems like after talking to a lot of sponsors and forum members on here, the best way to go is changing pistons. I am looking at either the Wiseco Pro Tru Series PTS523AS which is a 4cc dome that would give me about a 10:6:1 or some WS6store Heavy Duty Pistons which would give me about a 10:3:1. If anyone else has piston recommendations please let me know. Thanks.
Old Sep 20, 2018 | 06:09 PM
dawgs74's Avatar
Would ls2 pistons work.....I'm in the same boat, just picked up a l96 but I wanna bump up the compression like I did with my lq4 with ls2 pistons ....I also have 64cc ls3 style heads so I know if I just swap the heads I should be over 10.1:1, but with ls2 flat tops would that bring me closer to 11.1:1.....anybody have any thoughts on any of this...........thx in advance
Old Sep 21, 2018 | 07:48 PM
SLWRDE's Avatar
Veteran: Navy
Dawgs,
After talking to a couple of the members on here and some vendors, it looks like I am going to be purchasing WS6Store's 6.0L Heavy Duty Pistons and head gaskets with a 4.085 bore and .040" thickness to replace the stock dish pistons with valve reliefs. The guys at WS6Store said that they have used their pistons on 6.0L iron blocks and they measure 0 deck. If my calculations are correct I should be around a 10:5:1 or a little bit higher with stock L92 heads. So with you using the LS2 pistons which usually stick out of the hole about .007 and a .051" head gaskets, you are correct 11:1:1.
What cam are you thinking about using?
I am trying to decided on one of these:
Cam Motion LS3 Titan 3: 227/237 .621/.604 113 + 3.5
TSP Stage 1 LS3 225/230 .629"/.615" 112 LSA
TSP Stage 1 LS3 225/236 .629"/.615" 112 LSA
Katech LS3 Torquer: 225/237 .579/.598 113
BTR LS3 Stage 2: 225/238 .612/.585 113+3
WS6Store/RPM Speed High Lift ASA Cam: 226/236 .600/.600 110
I am even considering talking to Pat G and EPS to spec me a cam
Old Sep 23, 2018 | 04:00 PM
dawgs74's Avatar
Talking
Originally Posted by SLWRDE
Dawgs,
I’ve had good luck with the asa cam in my flat top 5.3 and flat top 370”...... I might go for a night lift asa cam.
Old Sep 23, 2018 | 04:02 PM
dawgs74's Avatar
I personally like the 3rd one you listed
Old Sep 23, 2018 | 04:04 PM
dawgs74's Avatar
I’ve had good luck with the asa cam in my flat top 5.3 and flat top 370”...... I might go for a hight lift asa cam.
dawgs74's Avatar
High lift asa cam
Old Sep 23, 2018 | 05:44 PM
SLWRDE's Avatar
Veteran: Navy
WS6Store sales the high lift ASA cam and I have heard of people getting good results with that cam.
Old Sep 24, 2018 | 11:06 PM
dawgs74's Avatar
Will have to check em out
Old Oct 5, 2018 | 06:42 PM
dawgs74's Avatar
Started to tear down my l96 today.....definitely gonna get ls2 pistons to get me into the 11:1's compression zone
Now time to get the stand and picker and bring this mess inside and see what these bearings look like.......how did your pistons look? 225k mile $800 ebay l96 complete with intake to run lpg.....i can sell this top end and get my money back....lol!
Old Oct 5, 2018 | 10:00 PM
SLWRDE's Avatar
Veteran: Navy
I bought a brand new crate engine for a pretty sweet deal so the pistons were brand new. Doing the same thing you are doing in regards to replacing the pistons for more compression. Trying to sell everything that I don't need to buy parts that I do need. That way the wife doesn't get onto me about spending money on my car. lol
Old Oct 6, 2018 | 06:53 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Spending an extra $20 to patg to get the same spec cam could be spent somewhere else.
Also, every ls deck height is different. I have assembled 4 or 5 iron 6.0s and had 0 deck but they may be a tad below or above, so please measure before buying gaskets.
You wont have to rebalance your crank if you just drop in flat tops. Ive had that checked.
Old Oct 6, 2018 | 11:58 PM
dawgs74's Avatar
Yeah that's what the guy at the machine shop guy told me when I did my 5.3 when he put them on the rods he weighed them and he had to use the 4.8 wrist pins instead of the new ones that came with the pistons to get the right weight. ....that motor runs hard!
Old Oct 7, 2018 | 05:55 AM
That doesnt make much sense as the wrist pins are nearly identical in weight at 50g.
Old Oct 16, 2018 | 07:10 PM
dawgs74's Avatar
Well they were cheap dnr flat tops if that makes a difference. ...like $140 for the set....lol. on another note .....got the l96 prepped up and painted ready for assembly. ....
Old Oct 24, 2018 | 09:06 PM
dawgs74's Avatar
Installed cam and heads today....just about done with this one!!!!
ls2 pistons went right in!!!!
Old Oct 25, 2018 | 12:59 AM
Did we set you up with the pistons also? hard to keep track lol
Old Oct 25, 2018 | 12:00 PM
SLWRDE's Avatar
Veteran: Navy
Nice build. What size head gaskets are you using?
