Ls3 sleeves
Old Jun 22, 2018 | 03:36 PM
Lsnewbee's Avatar
Default Ls3 sleeves
Does anyone know where to get some oe ls3 sleeves need 1 maybe 2 but I dont wanna spend 1500 on a set of darton sleeves. Can someone point me in the right direction or any sponsors got any. Just trying to go back stock bore
Old Jun 22, 2018 | 04:08 PM
62nalide's Avatar
At that point I would think it be cheaper to find an Ls3 bare block for less. Have you priced out labor and stock sleeve prices? Seen bare blocks in the 600s
Old Jun 22, 2018 | 04:12 PM
Frankenstein's Avatar
https://www.melling.com/3-23-18-new-...0-bore-engine/
Old Jun 22, 2018 | 05:00 PM
ColeGTO's Avatar
You can't purchase "OEM" sleeves nor would you want to. They have "ridges" in the OD and cannot be pressed into place.
You can get standard Darton "replacement" sleeves for about $100 each.
Old Jun 23, 2018 | 08:39 PM
Lsnewbee's Avatar
Thank you all for the info. I'm looking at buying the block from a buddy for 150 so im just trying to see if its worth it or not
Old Jun 25, 2018 | 07:02 AM
cmysix's Avatar
all the information in the world at his fingertips and can't type "sleeves" into google and then "refine" the search to find ALL the information in the world on "engine cylinder sleeves" on his own. and then going to insult those who helped him by telling them he's buying a block for $150 what did he think he was going to get a couple of sleeves installed for $75?.
Old Jun 25, 2018 | 07:28 AM
Lsnewbee's Avatar
did you even read the original post I searched but no where sells or advertises a oe sleeve i found the Darrin sleeves. And how did i insult anyone other then you
Old Jul 4, 2018 | 05:20 PM
RaceDevil's Avatar
LA Sleeve will make you any sleeve you need
Old Jul 4, 2018 | 05:33 PM
Lsnewbee's Avatar
thank you I will check them out
Old Jul 4, 2018 | 07:04 PM
I had a sleeve replaced in an ls2 block. Bought the Darton replacement sleeve for like $100 or so, and my machinist charged me a couple hundred more to install it. Had to over bore all cylinders due to distortion (from the new sleeve install) and deck the block to cut the new sleeve down to deck height. I think I had like $700ish in it before it was fixed. I had nothing in the block money wise to start with, as I got it on a trade, so I felt ok about the situation.
Old Jul 7, 2018 | 09:48 AM
cookseyb's Avatar
Texas Speed installs sleeves every day...
Old Jul 7, 2018 | 11:21 AM
Jimbo1367's Avatar
Does TSP stress relieve to blocks afterwards?
Old Jul 7, 2018 | 06:19 PM
cookseyb's Avatar
Not sure but they had a area set aside for boring and sleeve installation. They use Darton sleeves. I'll check their website a see the process if I can
Old Jul 8, 2018 | 05:15 AM
cmysix's Avatar
this is ALL great info on getting a block resleeved or repaired but you missed what the OP said, he said he could get a block from a buddy for $150, but he was checking to see if he could just have A sleeve put in his IE he thought he could get a sleeve put in for less then $150, you know this guy wants 800 hp at the crank and he's going to do it for $500
Old Jul 8, 2018 | 06:27 AM
Dimeomboost's Avatar
I don't think so I believe he is saying his friend has a damaged ls3 block he is selling him for 150. He was looking into the cost of sleeves to see if the block was worth repairing after the cost of new sleeves and the 150$ initial cost from his friend.
Old Jul 8, 2018 | 01:53 PM
This.
which is why I posted what I did. I had about $700 in the block, after sleeve replacement.
Old Jul 9, 2018 | 02:03 AM
RaceDevil's Avatar
Not all shops will do sleeves in aluminum blocks because they know there is stress relieve involved and dont want the headache of it
other shops will do sleeves and not do stress relieve,it will work most of the time but after the block gets hot the sleeve goes out of round and can crack
When installing one sleeve it will/can destort the sleeves next to it if improperly done
Old Jul 9, 2018 | 06:30 AM
Lsnewbee's Avatar
^^^^^^bingo^^^^^^^ I don't know why alot of people get so testy for someone asking a question on here if it is not worth it I'll pass on it
