lsx454 rod weight?
The downside to a shorter rod like that is that the crank has less room to fit a counterweight, so balancing will be tougher (ie $$$).
Rods typically have enough margin of safety in their design to prevent a mechanical failure of the rod itself.
Can you share any pics of the failed rod, the rod and main bearings from the engine, crankshaft, and any specific details of what was happening at the exact moment the rod failed?
Having said all that, here are the specs you are looking for:
GM Part Number - 19244040
Big End - 414g
Small End - 161g
Total Weight - 575g
I would agree that it looks like a fatigue failure of the small end. Jet boat racing does put A LOT of load on the rotating assembly. A 4.125" crank at 7600 rpm moves the rods and pistons up and down pretty quickly. Do you think it could have knocked the bushing out of the small end before it let go?
There are a number of options for you to choose from. I'd look at something like a Callies Ultra, Oliver or Crower I-Beam with a .927" pin and whatever length you choose to go with your piston of choice. I really didn't like the LSX454 rod when I saw it the first time. The thickness around the big end looks like it could use some more material, the .866" pin is quite small and the small end could use some help (obviously).
Good luck,
Cole
