Another 427 Build...
My target is 700rw to 1100rw based on NA vs. turbo, despite previous ambitions that have since become impractical. Not being a builder, it's hard to find the type of shop that specializes in performance builds, and tuners in my area. Seems like most of the top-level builders are back east.
Photo 1. Fresh off the press...
Photo 2. Front View - Raised 55mm Cam Location
Photo 3. Block w/ Darton Wet MID Sleeves
Photo 4. Block with Steel Caps - Custom Oil System Required
Photo 5. Billet Front Cover although a belt drive may be used.
Photo 5. Plazmaman Manifold Race Series with w/102 N.W. DBW-TB
The SS at Fesler Built in Scottsdale; being fitted with Recaro ErgoMed ES seats, and 90 lbs. of insulation
- Noonan: Billet Block
- Darton: MID Sleeves
- Std Deck Hight
- Std Lifter Bosses
- Finished Honed
- Plazmaman: Race Intake
- Plazmaman: Billet Eng Tray
- 102 Nick Williams DBW-TB (Std Version)
- CBM: Billet Front Cover
- Borowski: Billet Valve covers
- ARH Full-System 1-7/8 to 3" (ceramic)
- Harrop: OTR Air Filter/Intake
- Lingenfelter: Catch Can
- MSD: 8.5mm Wires
- Electric Assembly Stand
*Update* Not that the Dart Next block is bad, it's just that Darton is provisioning MID's for the Noonan or possibly other billet blocks. with the billet block I recall asking about potential issues/benefits with the MID sleeve, but the builder only mentioned how they haven't sold very well; due to the higher costs.
Thanks again for bringing this to my attention, as I have been sitting on this crated block, due to a medical setback.
Early billet wet blocks suffered from uneven between cylinder cooling which led to hot spots, LSM were amongst the frist to fix that - but I imagine there's no excuse for any of them having that issue now in 2018.
I run a very similar car to your SS - only much older. It has a twin turbo LS3 and I think the sweet spot us around 800 crank hp (about 700rw) - with DOT tires you can drive that all day and hook out of turns. I run 315's rear and 275's up front. On real street rubber... it's fun haha. At 1200hp you'll be point and shoot and WOT will only be possible on decent straights. It is way too much to track 1200hp around a road course for long and expect to keep cool - it'll also lap slower than at 800hp because you'll be white knuckling and sphincter puckering it trying to keep it on the track. At 800hp and decent rubber (tread rating around 100) you can give it death once the set up is right. I'm assuming you are manual. If auto - forget tracking it, the auto will poop itself if you turn too many laps - no way to keep an auto from heat soaking at that power.... well not with turbo TQ anyway, ask me how I know lolz A 700hp NA motor may see the auto last longer.
For drag racing and most street use an auto is fine - turbos and autos are made for each other
As for my intended config; it will be a street performance build, and I would be quite content @ 700whp on NA. The 1200 w/turbo (GTX4202).
Trans: While I was offered a manual trans, I opted for the auto due to my physical limitations. Circle-D will build-out the A/T with a twin cooler and an HD output carrier. I will swap the stock rear-end with a Camaro ZL1 case, LPW Ultra-IRS cover, combined with my Harrop/Eaton 8-pinion Truetrac core. I have a set of Forgeline SC1 Monoblocks with a modest 9.5" rear w/285's but will bump it to 10~" w/295~305. Anything more becomes a fitment issue.
Heads: The Zeta platform sedan engine bay is rather tight, so I'm looking at the Dart Pro-1 12º/285cc that maintains a close-to-stock fit-up while being more than capable with a good water jacket.
