LSX run in oil??
Ive got a new LSX b15 crate engine, trying find out what run in oil to use - mineral or fully synthetic?
the gm create instructions say to use a fully synthetic oil at break in?
general talk on the web seem to suggest mineral to start with or is that relating to older engines?
thoughts?
thoughts?
Start-up and Break-in Procedure 1. These engines once complete needs to be filled with oil. After installing the engine, ensure the crankcase has been filled with the appropriate motor oil to the recommended oil fill level on the dipstick. The LSX engines require a special oil meeting GM Standard GM4718M (this will be specified on the oil label). Mobil 1 is one such recommended oil. Other oils meeting this standard may be identified as synthetic. However, not all synthetic oils will meet this GM standard. Look for and use only oil that meets GM Standard GM4718M. Also check and fill as required any other necessary fluids such as coolant, power steering fluid, etc.
Full PDF
Full PDF
I am sure the Gibbs Break-In Oil would work fine as well. You just need a High ZDDP
non synthetic to seat the rings (6-10 hard pulls AFTER Oil & Water are at least
170* preferably 190*) and you are good to go, then switch to synthetic of choice.
Sometimes it’s hard to question a multi billion dollar company that’s has hundreds if not thousandths of engineers dedicated to just the engine longevity and reliability? A lot of people are recommending oils on what has worked for them, which is fine, but 9 out of 10 times they are talking about a rebuilt engine, not a brand new engine that has more quality assurances built in on the manufacturing process than any local machine shop could ever match.
So you (read all that) and if your engine fails soon after installation for whatever reason I’m sure you will be yelling for a warranty replacement is what (everyone seems to think mineral oil) as in your words are those people going to approve your warranty claim and get you a new motor? First they would probably deny your warranty claim due to the engine not being installed by a certified shop or mechanic and secondly they would deny your claim due to a oil analysis that indicates incorrect oil being used.
the interesting point to all this is to get these rings bedded in correctly, i will be racing the car, so iam not expecting it to last 100,000 miles
anyone thanks for your thoughts, but i think you are correct
and thanks for everyone else's comments
