Replacing heads in car????
OK, I'm swapping the heads "in car" 2006 C6 corvette, HOW? do you torque the bolts that are in a "BAD SPOT" for torqueing bolts, like towards the rear of the engine compartment? the drivers side LOOKS the worst. haven't got everything unbolted and out of the way yet but it looks like it might be challenging, any tips? TYIA
It is not too bad if you have all the right tools. First make sure you have a big torque bar it makes it easier in the tougher places where leverage can be tough. Also make sure you have an assortment of extensions. With the Corvette in the back there where the motor is under the cowl it can be a challenge. With the power steering in the front if you have a 30/45 degree open end 15mm you can get the bolt in the front without having to remove all the power steering stuff. Also check out the Corvette Forum C6 Z06 section they have a sticky about how to remove heads in the C6.
I finished torqueing the heads this AM, it really wasn't that bad. I used ARP studs and it called for 25 50 and 70 ftlbs in three stages. I had a couple of different size extensions ended up just using one size, Used my 3/8's snap-on tq wrench for the 25 and 50 ftlb pass and used my snap-on 1/2 tq wrench fo the 70 ftlb pass and back to the 3/8's for the 28ftlb pass on the small studs. I used a single edge razor and a 3M scrubby pad and WD40 to clean the piston tops that was easy a lot of the carbon was flaky, I wonder how it stays on the piston? Fingers crossed, it should be running tomorrow. I wonder how just heads will effect the tune?
heads
