500ci ERL cam options ?
hi guys,
what cams can i use in a 500cui erl engine?
i want to go solid roller , i have read its not to easy its a tall deck block with deck plates and stock cam location stroke ist 4,5".
or is only custom cams required?
Super Hulk Smash
4.5" with the stock cam location is going to need something custom. Like KCS said, a small base circle cam is a must.
On the Tall Deck LSX or Dart blocks, the cam location is raised .300" or so to move it out of the way of the longer throw cranks. And even they need smaller base circle cams.
LS1Tech Sponsor
Received 1,241 Likes
KW
LS1Tech Sponsor
Call these guys ---> www.cammotion.com/low-lash-solid-roller <--- or you'll just waste a lot of time and money!
KW
KW
Get with Horsepower reaseach in McKinney TX. call up there and ask for ERIC or Anthony and tell him Nash sent you! They are the ones who have built the biggest displacement LS 527Ci! I have seen it with my own eyes. 60mm cam over a inch of lift. Has a 1200lb open spring it’s insane. Here’s a picture of it when i was up there before PRI
yes sir. 1200lbs open spring pressure. don’t worry i said the same thing when they told me that i was like wow! but it has like 1.180 lift. If you look at the head gasket it’s also a spacer due to piston sticking out of the whole so much positive deck
