COMP Cams Ultra Pro Magnum Rocker Arms Chevy LS3
Anybody running these?
Thanks for posting fellas!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Do you have a cam yet? I have a Cam Motion custom grind for my 416 with 1.8 rockers, only 3 test passes on it went 10.17 at 3400lbs. I'm going turbo and just getting ready to list it. Grind # XA246-365 258-355 112+4.
It's a bigger than your 236 but if the description of your build is accurate it is very streetable as long as you use roller rockers, my car is an NA Drag Week car and I actually ended up with a 10 degree bigger cam after testing several.
