4.8 turbo or 5.3 turbo?
The 4.8 will be the stronger of the two...with all else being equal...due to the shorter (stronger) arm or stroke. The Oem rotating assemblies are plenty strong enough for 800 whp and a good beating. Lots of guys here do this daily.
so only do heads don’t even touch bottom end?
May be easier to achieve (less stress) with an LY6. Larger bore and valves, same durable iron block and external size. That's how I'd do it, anyway, but I'm just a tool. If I were to do a turbo motor, it would be an LY6 build, sans VVT.
07 to 09.5 ly2 is the best stock long block for boost in my humble opinion. No vvt, no dod, no afm. Upgrade the valve train (cam/springs/pushrods/3 bolt cam sprocket/trunnion up grade) and run that thing. Make Shure you have a tuner that is top notch. Oh and a really good fuel system. Good luck no matter what path you choose 😈
